ChadS99SVT
I made a post a while back about my tdi getting slightly hot on my way up skiing. Reached 233* twice on two different sustained climbs.
VW checked everything at my 10k service and said operating normal. They even opened a tech line with corporate and no concerns.
I finally went up again and this time I was more aware and played with sport mode a bit to increase rims in hopes of keeping out of max boost. It seemed to work better as max temps hit 226.
I'm curious if you guys have any advice or imput on the subject. Above 225 the gauge moves. I don't like having to babysit the gas pedal fr fear of damaging or overheating my car.
Keep in mind this is all with just me in the car. Next week my parents are in town and I will be headed back to the mountains. This time loaded up with an additional 500lbs of people/gear. So I'm a little nervous.
Few questions. Does RPMs affect water flow? I assume our water pump is electric so I'm not sure it works the same as belt driven pump.
My EGT temps stayed pretty constant at 700-900 with upper ranges being near max temp for this past trip. Is this damaging the turbo running this warm? I know it's still less than a regen but I don't know if it's heating the turbo differently than during a regen.
Do diesels tolerate high operating temps like that? 233ish? What point do I cause damage or should I be concerned.
Also does being in sport mode really benefit me in terms of keeping it running cooler?
Thanks for the points. My guess is I need to worry less but I think my concerns are somewhat legitimate. It makes me wonder if temps are like this in the teens. What are they going to be. In summer when its 80+
