There is a thread on V-tex about this in the B7 forum. It indicates that the newer Jetta rims will fit but they have a different offset. It lists the offset... but I don't remember what it is. The Jetta rims are available at TireRack for $45-$50, but no listing for Passat rims.
I just bought a set of these, new in the box. $80 each, no centers, they are VW Audi wheels, 16 inch X 6 wide, 5X112MM, they fit over the front calipers. I plan on a set of 205-65-16's.
I don't know the offset, but from measuring, they run inside the existing rim footprint, inside and outside.
I like the narrower tire for snow, they are slightly taller than the stock 18's, the 215-60-16's are slightly shorter.
