microsoot
Hello:
Oil leak diagnosed on compression fitting side of turbo oil feed line through inspection camera.
Is it this easy or am I missing something?
Replace new line, and use 2 new mounting clamps, 2 new copper crush washers on banjo bolt side, and tighten compression side.
Any advice on torque values, or seals on compression side or inserts on turbo mating area to suspect, or anything to remove to ease installation???
Good suggestions, experience, watch out for's would be appreciated
Thank you
Thank you
