I just bought a 1999 mk4 TDI and I am having a problem with starting it. I find that it it will take a lot longer to start in the morning, I feel that it is a fuel issue. Is there a check valve in the sending unit that would keep the fuel from losing pressure? I havent had the timing checked with a vag, but it did look like someone had advanced it. I have adjusted the timing to get it to start well warm but still have a very long crank time cold. If anyone has had this problem or can offer help it would be much appreciated. I don't feel it to be a timing issue.
