robtechno
- Joined
- Sep 27, 2007
- Location
- Hudson, NY
- TDI
- 2015 Golf 2.0 TDI.Sport wagen 53K. Previously a Jetta 06 with 205K. A5-BRM,
There are many old posts but they are very confusing about the bleed order. Some say RR first and some say LF first?
What is the correct order?
Some say that bleeding with an ABS system you need the VCS system to run a program, is this a must or will it work without.
Who has the correct answer, my TDI is from 2006, one of last Diesels in that year. I do all four brakes replacement and front wheel bearing so it should be good time to do a flush but I need answers on the above questions.
Thank you for you help here.
Rob
Rob
