I want to use the gauge cluster and electric fan out of the Passat so I thought I would reconnect the Passat fuse box in the Toyota.
Then I connected
H1/01 ( starter run ) to toyota ST ( BW )
H1/02 ( battery power ) to toyota AM
H1/03 ( run power ) to Toyota IG
H1/04 ( start ) to Toyota IG
H1/10 ( power when off ) to switched 12v
Resulted in nothing except the cluster chiming when I tried to crank the motor
What do I need to do?
If the clutch and brake pedal position switches are not used do I just ground them so they act as if they are "open"?
Then I connected
