Jlblob
So the story goes that a while back I got my Chevy LUV stock as could be, rebuilt the 1.8 in it and did little things, couple years later was bored and built a pretty mean Chevy 4.3 and dropped it in with a 5 speed. Few years later I am tired of barely getting double digit mpgs and I almost never have a need for the power the truck has.
So at this point the plan is to sell the 4.3 and buy a TDI donor car. Was considering an ahu since donors are so cheap and I don't have to worry about immobilizer deletes or as much wiring but I do like a lot about the alh.
Still deciding how I want to go forward with the transmission. I can either get a Toyota trans and an acme adapter setup and have a new driveline made. Or I can go buy a steel plate and see about adapting this tdi to my Chevy 5 speed seems like it is brought up a lot but I don't see it done. already have a real nice custom driveline i had made to put the chevy 5 speed in the luv and it's a V8 style trans so with over 10" of clutch the tdi can live happily on a stock clutch even with a lot of modifications.
Conveniently I already did a ton of rewiring in the luv so everything is set up on standalone circuits through a Jeep Cherokee fuse/relay box and the whole stock system firewall forward was removed and rerouted to that box. So if I need to pull 12v or set up a trigger system I have to hardware available and easily accessible
Mainly looking for the huge mileage increase and not dealing with a carb anymore. And of course having a TDI luv would be pretty sweet in its own right.
