greenzuki
Hello, everyone,
greetings from Vilnius.
Done some search about my problem but found so many problem solving suggestions that now at the moment I'm really confused. Maybe anyone can help me sort it.
From a beginning. About two months ago I bought a vw passat b6 TDI PD with 1.9 BKC engine. It had 140k miles. After I bought it I check mileage on VCDS, it showed 216k miles. (stupid me to buy it). It had new dual mass flywheel, rebuilt turbo charger and conditioner compressor. It was driving fine, well, at least, I felt a lack of power (77 kw), but I thought it was normal considering a weight of a car. I had a (I thing) normal fuel consumption, on idle when warm it was 0,24 U.S. gallon per hour and when going 60 mph about 40 mpg. So no big problems.
Three weeks ago suddenly whole car started shaking on idle at a junction. When it gets higher rpm than idle - it's okay. So I drove it home and plugged in VCDS. It showed me P302 #2 cylinder misfire. Hm.. Then I noticied, that my mpg got poor - when driving it is about 30 mpg and on idle, when it shakes - it is 0,48 U.S. gallon per hour.
When I'm starting it cold - no problems. Idle is smooth. And only after 10 ir 15 minutes of ride, when engine is getting warmer - it is starting to shake on idle. Sometimes idle is okay when hot, but rarely.
Checked VCDS for engine meas.blocks group13 for Injection quantity deviation:
1# -3.01 mg/str
2# 2.99 mg/str
3# -0,45 mg/str
4# -1,29 mg/str
Then I fueld my tank to the top and added some injector purge. But didn't ride a lot, so no difference yet. Then I found, that many people have idle shaking problem with TDI PD. And many of them fix it with camshaft timing adjustment. So I checked mine it was -2.5. I've tried to make it between 2 and 5 more to a 5, bet managed to do only 5.4. I believe that it isn't big deal, so left it.
Some driving test. And there's still idle shake problem but I had no lack of power like when I bought a car. It was really more fun to drive. And MPG didn't change it was still poor. Yesterday I've tried to start my car on a warm garage. But I had to try to do it 3 times and it started hard, but smoothened.. So it is getting worse. And I really don't know where to start..
When I was adjusting camshaft timing I noticed, that my timing belt tensioner isn't tight as it should be.
So now I bought new timing belt kit and I am replacing it at the moment.
I have many doubts on what should I do next if it won't help. Could loosen tensioner make this kind of symptoms? Maybe I have fault injector(-s)? Maybe it is a camshaft with lifters? Could they make this kind of symptoms? I'm on a low budget at the moment I can't just replace everything. And I need my car everyday badly .
So my next steps are:
1. Finish with timing belt kit.
2. Clean egr (btw it is not in a bad shape, clean enough) and intake manifold isn't clogged.
3. Check injectors wiring loom resistance.
4. Adjust injector clearance lash.
4. Inspect camshaft lobes and lifters without removing them (don't have special tools).
5. Check compression on cylinders but only in few days.
Any other suggestions, tips on this problem? I'll keep updating it.
1# -3.01 mg/str
2# 2.99 mg/str
3# -0,45 mg/str
4# -1,29 mg/str
