Another one bites the dust!...What next???
OK - First of all - fanstastic write up of the procedure to adjust the set screw. Thanks to all who contributed! (O.C.TDI, sixamskier, jsrmonster, DanG144)
I ran the measurements using vagcom and I was at a difference of 265 between high and low boost. I too am experiencing the unpredictable lack of power and black smoke. Clearly a candidate for the set screw adjustment.
So I read the entire thread as well as most of the ones referenced in this thread. I saw that there was a significant risk of snapping the flange as I try to loosen the lock nut prior to tightening the set crew...so I soaked it the best loosening oil i know of prior to trying - Kroil. It's worked in a zillion scenarios for me, but not this one.
As soon as I tried to loosen the lock nut - with the very lightest of torque - this happened: I BUSTED the set screw mount!
So - pardon the pun - now I'm screwed! As I understand it, I
may have three options:
- Install a whole new turbo? (Too expensive for me right now)
- Make some sort of DIY mount for the set screw. (Need more info on how this is done.)
- Zip Tie method. (Can this approach be used now that I have broken this mount?)
I'm really flustered and could use your guidance on next steps. I would like to fix the problem as inexpensively as possible, but I would also like to make it as long term of a fix as possible.
I look forward to any guidance you can provide!
Thanks.
Ed
