Old February 16th, 2015, 12:11   #1
JBell
TDI(s): None
Default 0W-30 VW 507.00 Oil Hitting the Market
Just got off of the phone with Pennzoil.
Around the end of March/early April, Pennzoil Euro LX 0W-30 oil will be released, which will have the VW 507.00 approval on it. This oil will be part of their Platinum line.
Haven't seen it discussed here...thought I'd share.
JBell is offline   Reply With Quote
Old February 16th, 2015, 12:46   #2
14tdipassat
Yum. Another way to hopefully fend off the turbo problems in our NMS Passats.
14tdipassat is offline   Reply With Quote
Old February 16th, 2015, 13:21   #3
yatzee
yatzee's Avatar
TDI(s): see sig
i hope that it'll be easy to get (maybe walmart would carry it?)
2015 Passat TDi 6 spd, 2008 WK CRD, 1991 405 mi16, 1992 300D, 1986 and 1987 190e 2.3-16, and a couple 2 wheeled things
yatzee is offline   Reply With Quote
Old February 16th, 2015, 13:27   #4
Busydiver
Default Penzoil better?
I am no oil expert but seems from your comment you have a better feeling about Penzoil than other name brands. Interested to hear your thoughts. Thanks
Busydiver is offline   Reply With Quote
Old February 16th, 2015, 13:53   #5
tikal
Fuel Economy: 37 MPG (~ 45% city)
Default Platinum = GTL?
Thanks for the post Philth. I have also heard similar feedback from Shell a few weeks ago. The upcoming Pennzoil Platinum Euro LX 0W-30 is already in the Mercedes Benz list of approved 229.52 list of oils! I wonder if it will be similar to this oil available in Europe:
Shell Helix Ultra ECT C2/C3 0W-30
Some questions:
1) Are all the Platinum line of Pennzoil oils derived from GTL (gas to liquid)?
2) What are your thoughts of this Platinum oil vs. the current Pennzoil Ultra Euro L 5W-30 which has excellent specs (such as HTHS = 3.68!)?
tikal is offline   Reply With Quote
Old February 16th, 2015, 13:56   #6
TurboDieselPoint
I don't think it's the Pennzoil part he's happy about; its the 0w-30 spec.
One of the theories about the cause of CKRA turbo failures is that the turbocharger fails to receive adequate lubrication when the oil is cold and thus thicker than it is at operating temperature.
TurboDieselPoint is offline   Reply With Quote
Old February 16th, 2015, 15:09   #7
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Excellent news.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old February 17th, 2015, 07:06   #8
14tdipassat
Correct All things being equal - and I know they aren't always equal - when cold, a 0w30 will flow better and warm up quicker than a 5w30.
Old February 17th, 2015, 07:17   #9
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 39 -43 mpg: 12 Touareg TDI, 39/31/29 mpg:
Yes, actually this is already out for MB engines requiring the Mobil One ESP MB Formula M 5w40, aka MB 229.51 specification (5w30) to MB 229.52 (0w30). There are some oils that in effect share the VW AND MB specifications. Since 5w30 is actually a key issue with VW 507 specifications, the only question is IF VW will change the numbering to reflect a change in viscosity (0w30).
So for example, the 14 MB GLK 250 BT is a TWIN TDI !!! It can use 5w40, 5w30, 0w30. I got 24 units of Formula M, 5w40 , MB 229.51 and will use that for @ least 3 oil changes of a minimum of 10,000 miles each, before reading the tea leaves on the next greatest brews.
ruking is offline   Reply With Quote
Old February 20th, 2015, 08:50   #10
Rico567
I agree, this is great news, and I will switch without hesitation to a 0W-30 that's 507.00 approved. We've used nothing in our SAAB gas cars but Mobil 1 0W-40 for 15 years, on both Garrett and Mitsubishi turbochargers, and nary a hint of trouble. Have around 170K on the one we have now....
[URL=http://www.fuelly.com/driver/rico567/passat]
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old February 28th, 2015, 05:09   #11
dieselhaze
My local autozone carries this mobil one ESP 0w30. I have looked at it but there is no 507 approval on it.
dieselhaze is offline   Reply With Quote
Old February 28th, 2015, 21:16   #12
tikal
No, it is MB229.52 approved.
Old March 3rd, 2015, 18:58   #13
Pitchar
That odd, idparts says ESP is 507 approved but I guess if it's not on the bottle it isn't
http://www.idparts.com/catalog/produ...oducts_id=3134
Pitchar is offline   Reply With Quote
Old March 3rd, 2015, 19:29   #14
14tdipassat
Mobil 1 ESP 5w30 is 507 approved. Mobil 1 ESP 0w30 is not.
Old March 4th, 2015, 15:06   #15
FowVay
FowVay's Avatar
Pitchar, the IDParts product is the Mobil-1 ESP 5W-30. This DOES carry the VW 504.00/507.00 rating.
The product in this discussion is Mobil-1 ESP 0W-30 which does NOT carry the VW 504.00/507.00 rating presently.
FowVay is offline   Reply With Quote
Castrol SLX Professional LL03 5W-30 (504.00/507.00) Oil blue_jetta Private TDI Items for Sale/Wanted 2 May 30th, 2014 09:37
Mobil 1 ESP Formula 5W-30 VW 507 00 sohccammer427 Fuels & Lubricants 208 May 22nd, 2013 20:48
VOA Fuchs Titan GT1 Longlife 5w-30 VW 507.00 wensteph Fuels & Lubricants 14 August 16th, 2011 13:42
Shell's 5W-30 Helix Ultra Extra 504.00 / 507.00 Motor Oil Sloppy Snood Fuels & Lubricants 47 December 21st, 2007 15:57
VW TDI OEM Factory Fill Oil is 0W-30 SkyPup Fuels & Lubricants 29 July 28th, 2002 05:29
Page generated in 0.15363 seconds with 11 queries
[Output: 125.94 Kb. compressed to 104.87 Kb. by saving 21.06 Kb. (16.73%)]
