My beloved 1998 Jetta Lifeless please help.
jacobssTDI
Dayton, Ohio
Jetta 1998 White
Well it happened, I was accelerating off a ramp, all the sudden engine power died. I crused to a stop of the side. I crancked, engine turns fine I don't hear any interferance, no big puddle of oil. No rods sticking out of the engine. But it acts like it is not getting fuel.
First though timing belt due the sudden nature of my power loss. But I would not expect the car to turn over with out some audiable sign of its demise. I need to do the belt, it is due @ its next 30KM, which was on the plate down for this next weekend.
What else is there to check, shudder valve?
Also does the TDI valves meet pistons if they get out of sync?
bowlerman
medford, NJ
2001 jetta tdi black
u have an a3 if its a 98, i have the same one. we dont have an anti shudder valve, so dont worry. maybe u have a fuel leak to start? look at the clear line to injection pump and check. engine light? get the code. the valves i think also get preety close to the piston. could be alot of things? does it run now? you hear any kind of sounds? tell me alot more so i can help?
bowlerman
medford, NJ
i was also thinking relay 109 but if it died wouldn't alot of electronics not work. herm said relay 109 does alot lot of things. can someone list what relay 109 exactly does?? so we all know. thanks
Big Red
Newark, DE, USA
If you have ignition lights on dash, 109 should be fine.
Did you just fuel up anywhere?
Search for fuel pump O-Ring. I had a problem with this once but it fixed itself. My car ran, but had almost no power. Air can get in through the O-ring.
weedeater
Reston, VA
Jetta, 2001, Baltic Green
Did you look at the belt? When mine went, the engine cranked just fine.
109 is the main power relay that energizes the ECU. Without it, the engine quits. Dead. But the instrument lights also go out. The 98s had a faulty relay. If you haven't replaced yours already, they are about $20 and easily replaced.
Oo-v-oO
Live Free or Die, USA
98 Jetta Expired... Now 2000 Golf & 2002 Golf
'98 Jetta has no anti-shudder valve, so that's not it.
The pistons and valves will want to occupy the same space if they get out of time. The valves and lifters usually lose this battle.
AFAIK, and I may be wrong, the A3s didn't have such a problem with relay 109 as the A4s did. It is worth checking, but don't count on it.
You can pop off the upper timing belt cover without too much effort to get a visual on the timing belt. Have someone else crank it over so you can look at the belt while it's turning over. If it didn't make a bad noise when it died, it may not be that.
I would start by seeing if the shutoff solenoid on the pump is getting power, and work backwards from there. A Bentley manual with a wiring diagram would be invaluable for this work. I have one and would be happy to answer questions if I can.
-Lee
Lightman
Sunny Florida
thats exactly how my jetta acted when the maf went bad. I was on the highway, flooring it actually, and all of a sudden, near total loss in power.. I made it home, but there was just no acceleration. Felt like a gas engine running on less than all the cylinders...
I know its kinda basic, but worth checking out the MAF. Thats my .02 non mechanically inclined cents.
GoFaster
Moderator at Large
Brampton, Ontario, Canada
2006 Jetta TDI
When you switch on the key, take note if the "check engine" and "glow plug" indications come on.
YES - engine electronics are getting power.
NO - engine electronics are NOT getting power, and the Relay 109 is the most likely cause.
There is a troubleshooting guide in the TDIFAQ. Stalling and no-start situations are covered.
dzcad90
Rolex & gin
Joliet, IL USA
Jetta - 97 (RIP), '03 (Sold), '09
My 97 Jetta made no audible noises of valves meeting pistions when the timing belt broke. Sounded like it wasn't getting fuel either. Take a look at the timing belt, it only takes a couple of minutes to inspect. May save a lot of needless troubleshooting, or set your mind at ease.
Did you have any lights come on when the car stopped?
[ December 04, 2002, 16:23: Message edited by: dzcad90 ]
Big Red
Newark, DE, USA
98'S Don't have MAF and 109 problems that I'm aware of.
0. Fresh fuel? Could it be bad or wrong?
1. Peek at timing belt through cover.
2. O-ring on Fuel Pump
Stephen P
Towson, MD
Jetta 97 Green
My 97 jetta did the same thing. It ended up being the timing belt even though it was changed 12,500 mi before. Cost of repair was $3,700 dollars for new belt, new pulleys, two new valves the head had to be rebuilt and a new battery. VW of america covered all the costs because of their 1yr/12mi warranty. I was 500mi over but I went in like a thunderstorm on a nice summer day. They took 5 weeks to do the repair and the battery was the hidden costs. Obviously nothing was wrong with the battery but they charged me $109
Cabok
Le K long
36 mois sans intérêt
Jetta TDI Wagon 2003, Rabbit '81 (1.8T)
If the engine shut off completely, I would go for the fuel shut-off selenoid. Check the wire, mine once failed 'cause the wire was rubbing against the plastic wire shield, and finaly cut the wire. If it just lost power, it could be your N-75 valve.
