I came across a TDI in need of some TLC. The owner bought it with engine noise. Well, the engine noise turned out to be a broken crankshaft just next to the connecting rod bearing. You can still turn the engine over (he did this as I was standing there) without any binding. What are the chances that the head isn't trashed? Is the broken crank a common thing? Did some searching on here, and found one other instance of it. Car has 180K on it and the timing belt is still intact, so not 100% sure what caused it. Looked at the turbo and there is minimal play (was thinking maybe blown seals and sucked oil into the engine. Can buy it for a reasonable price. Any thoughts?
