psrumors
Anyone else using the Newsouth single gauge pod? Installed mine last night and the back of the steering wheel rubs where the pod slides down between the wheel and column. I imagine I can cut the plastic off but curious if anyone else is having that problem.
Also installed the Aeroforce interceptor but the steering wheel hit the gauge bezel. Luckily it is aluminum so I was able to grind it down enough the wheel misses it.
