VWinMS
I have an 01 Jetta with the 1.9 TDI and 01M transmission. The transmission was working just fine (other than sometimes not going into reverse when warm).
The IP was leaking on the lower radiator hose. I replaced the gaskets on the IP and found someone with VAGCOM and set quantity adjuster at 3.0.
After about 30 miles of driving with no issues, I noticed where the fuel was leaking on the radiator hose prior to IP fix, there was what I will call an aneurism and I felt it best to change the hose. I drained the radiator into a new bucket, changed the hose, and poured the same antifreeze back in through the round (overflow?) bottle. (I didn't realize how tough it is to find G12 in local stores.)
Anyway, once all the AF was back in, I drove the car about 1/2 mile and the transmission downshifted as if I had "punched it". However, I was driving 35-40mph on an absolutely flat road. The transmission has never had any issues in forward gears.
I know these transmissions have issues, but it seems this was directly related to changing the radiator hose, specifically, draining and refilling coolant. Can someone please help?
