AndyBees
- Joined
- May 27, 2003
- Location
- Southeast Kentucky
- TDI
- Silver 2003 Jetta TDI, Silver 2000 Jetta TDI (sold), '84 Vanagon with '02 ALH engine
Sorry if I missed this in the FAQs...... if it was there?
Does anyone know of a vendor (besides dealer) that carries the Heater/AC fan switch?
In recent months, I have had to repair/replace two of these switches(NB and Golf, ALHs)
In both cases, the metal tab that makes the connection on the 4 different speeds had broken loose from the plastic rotating disk. On one of them, there had been significant heat causing the assembly to distort enough that the AC buttom would not function properly (stayed in).
Those switches are obviously problematic. The repairs I have done may or may not last very long. And, junk yard supplies are slim as well as "used" with the same potential issues.
Also, the entire bottom part of the dash has to be removed, including the console, to access the Heat/AC controls....big job! But, in one case, was a good opportunity to repair the broken Glove Box hinge!
