Hit my first 600 mile tank!
Lax02TDI
Abilene
2002 1.9L 8V
Got my first 600 mile tank! Almost all are highway miles. Only put 5 bucks in at 530 to make sure i wasnt too low when i got it. Got it in my 02 full stock jetta
Curious Chris
Pineview GA
Jetta Wagon 2003 RIP Rockford IL
Wow I hit just under 600 miles on every tank minimum. And that is driving 30-40 miles an hour through town. All highway I get very close and have hit 700 miles on one tank.
scooperhsd
Kansas City KS
NB, 2000, RED(5 Speed conversion) 2015 Golf SE
I don't even think twice about hitting 600 miles on a tank (on the 2000 NB) - if I fuel before then, it's more for convience than I "need " to fuel up.
700 Miles - now THAT is an accomplishment - I have hit that a time or 2 under the right circumstances.
South of Boston
I haven't had a tank under 700 miles in I don't know how long. My average miles per tank over the last 134K is 697.
Do the ventectomy!
Lax02TDI
Abilene
2002 1.9L 8V
My average is about 500. I doing the Ventectemy when i finally get home for long enough to do it! Slowly doing what i can to Mod her out. First big step is trashing the bloody automatic trans and popping in a 6 speed
Tdijarhead
Lawrenceville PA
I only ever hit 600 a couple of times with my old Golf with the auto. My newer 05 with the 5sp is almost always over 700 I've even had a handful of tanks over 800.
UhOh
PNW
As has been noted, easy with a manual, not so automatic with an automatic.
I'm currently trying to record an 800 mile tank in Golf #3 (for the trifecta).
Das
Hampstead,NH
Silver 2002 Jetta GLS TDI sold377k , 2012 black A3 TDI wagon
Can drive like I stole it. 80 plus and still get
700 to 750 and still have a 1/8 left.
All stock except the sprint nozzles and vented.
belome
Mid MI
2002 Jetta GLS TDI 5-speed
I made it to 600 miles... well, except that I put 5 dollars in just in case. :rolleyes:
h4vok
Denver (ex MN)
2003 Jetta TDi 5sp 171k
I normally fill up around 500 miles, but I have no doubt I could go over 600. I fill mine when ever I get to a 1/4 of a tank always have done it that way in previous cars. I have not touched the vent.
251
TDI Owner/Operator
NW IN
2015 Passat TDI SEL
When I had my 2002 Jetta I did several tanks of 1,000+ miles each. Yes, it was about empty but I never ran it dry either. So 600 miles is nothing - gotta shoot for 800 or more per tank to be considered an accomplishment in an A4 platform ALH.
jokila
Houston, Texas
2003 Jetta GLS, Manual
ummm.. ok... you are getting 62 mpg (assuming a 16 gallons)?
This is not typical or normal so expecting others to get that makes your post bragging at best, disingenuous at worst.
UhOh
PNW
Hit my "third"* 800+ mile tank. Third as in third car to do it: first for my new blue Golf. 14.996 gallons to refill. 53.5 mpg. Could have driven it more gently, but... at this point it start to become harder to do not for the car, but for the driver! (driving with a light foot for 800 miles is really tough!)
jokila
Houston, Texas
How many miles did you go with the low fuel indicator on? I would recommend carrying a miteyvac and a pair of pliers. ;)
UhOh
PNW
51 miles. I've actually done more in another car: first try at 800 miles. And, I'm driving pretty much highway, so my FE average can be expected to be around 50 mpg.
My general rule is to try to not exceed 40 miles following the fuel light coming on.
For those not familiar with the ventectomy, it doesn't affect how many miles you can go after your fuel light comes on. You can freak out people by pointing at your tripometer and your fuel gauge after using say 1/8 a tank- it'll be showing an insane amount of miles (because your gauge isn't graduated for the extra fuel you're shoving into it): I think you can hit 200 miles (which, multiplied by 8 would give you 1,600 miles- you're NOT going to get 1,600 miles!;); at 1/4 it's like 300 miles, and then by 1/2 a tank you're at 500 miles or so).
jettawreck
Northern Minnesota-55744
2001 Jetta and 2003 Jetta
I've done some 900 mile tanks (two different Jetta sedans) and run with the low fuel light on for almost 75 miles (couple of times with a fuel can along "just in case").
My max fill, if I recall, was 16.3 gal.
It's been a few years now since I now seem do more short trips and errand runs instead of my work commute which made up the majority of the miles years ago.
800 mile tanks were rather common back then.
jayb79
Exeter,NH
I can usually get just under 900 (870ish, three trips to Ct.) on a tank in the summer and it will take just over 16 gallons when I fill it.
jokila
Houston, Texas
In an unrelated conversation about mileage or fuel economy...
Yesterday I filled in 17 gallons in my tank. I reported that station to the Texas Agriculture Department's Weights and Measures division. I've never done that much fuel, especially when I estimated I had another gallon left.
By my estimation the pump was over reading by at least a gallon. That made their $1.99/gallon more like $2.12. The deception of these kinds of filling station owners needs to be met with tough enforcement. There were a number of stations that had 2.09 in the area.
UhOh
PNW
:eek:
Might also be concerned with fuel quality?
2015vwgolfdiesel
Oklahoma
2015 VW Golf S DSG Silver
What is a ventectomy?
