jimbote
Certified Volkswagen Nut
there are quite a few internal differences between a right hand pump and a left hand pump... camplate for one, and the timing piston goes the other way to advance/retard timing... internal vane lift and plunger may also be different ... but as Scott stated above the trans thrusts loads are reversed when winding gears backwards and on top of that you are now loading the coast side of the hypoids in drive forward mode ...why would a ip not run backwards? yea.. i doubt it would suck fuel... but 1 is 1... custom lines (if needed) and cam... mod the sucky part of pump so a lift pump can fill it..
may have to goto a rover pump.. as electronics i doubt like ccw... but i see no "reason" a diesel cannot be made ccw
Just want to clarify this is not what the OP is doing, flipping the trans still spins it in it's engineered for rotation, my above post is in reference to running an engine and trans in reverse rotation from it's engineered for spin
