cjharris02892
- Joined
- May 4, 2004
- Location
- West Kingston, RI 02892
- TDI
- 2000 New Beetle, 2000 Golf and 2005 Jetta MKIV w/BEW
Hello,
Bought a 2005 Jetta BEW with a 110,000. I did the timing belt because I did not have a history. Car has been running fairly well except for a slight lack of power. I hooked up the VCDS and found a code P3007. Cleared it and it reoccurs immediately. Car starts just fine and idles smoothly.
I have ordered a new camshaft position sensor and a set of intercooler seals (5 in total). They are coming in for the weekend.
Last night it threw a P0299 and went into limp mode. Can this be related to the P3007 or should I start Mighty Vac"ing" the system, N75, Turbo Actuator, etc?
Oh the joy of a new used TDI. BTW, a BEW in limp mode is still fairly drivable compared to an ALH in limp mode.
TYIA.
This is my 5th TDI all previous ones were/are ALH, 1st crack at a BEW. Not looking forward to the camshaft swap down the road.
TYIA.
