hamilgs
Changed the fuel filter on the '14 JSW MT6 TDI, and need to prime the filter prior to starting the engine, so get out the Vagcom (Hex/Can), turn on the ignition, connect Hex/Can. Goto Engine/Basic Settings and the drop down list where I would choose "fuel supply pump activation (or similar) is grayed out and only shows "No documentation available". I've not seen that before. Any advice?
It does not seem to easy to prime the fuel filter manually like it was on the '96 Passat TDI, and I'm hesitant to start the engine without first filling the fuel filter.
