cristicondor
2006 jetta brm,
the car starts very well when the temp is -23C (-9F) but it would almost not crank after a short 20 min ride or after the engine is warm.
If I cycle the glow plugs 2 times and wait 3-4 secs the car starts after a hesitation.
Before i go buy a new starter do any of you have any advice on what else should I check? which ground points should I check?
the battery is good, at cold the car starts at first engine spin.
thank you very much!!
