Skootyskoo,
My first issue you are not decking the block... I rarely find the block dead flat. If I am going to build for power, I have to start with flat cylinder head and block, to name just two components.
Just to dispel a generally conceived notion, just because you can pinch a .001" feeler between the block and a straight edge, does not necessarily mean everything is ok.
My technique for 'flat' on a block is to lay a machinist block across the webs between cylinders and lay the block over the bolts holes in line with the web at the sides of the block. If you shine a light behind the machinists block, laid on edge, and see light, the cylinder web is low compared to the outside edge of the block. Unless you have very high-end equipment, you otherwise, can't see it properly. Laser holographic imaging, we don't have in the shop.
Further, if you take a bastard file and strike across the head and do not touch the webs of the cylinders, again, the block is showing it is not flat. So, all this talk about which head gasket thickness is immaterial, if you end up going big power and blow the head gasket due to several thousandths gap between cylinder head and block.
To justify my position, whenever we set up to surface a block, many times we aren't interested in changing the piston projection height. That measure is made at the web between cylinders. There are times we deck the block and remove .002"-.005" from either side of the block to reach the point that we TOUCH the web. The reason this happens is the block tends to deform from head bolt tension and heat, making either side of the block deform and ride high compared to the centerline of the block. The webs become the 'valley' in the flat of the block.
As a contrast, the cylinder head,, especially when over-heated, tends to bow lengthwise. So, the two opposite deformations tend to cause the cylinder head gasket to blow between #2 and #3 cylinders, towards the manifold side. Our job when working to mate head and block is to eliminate, or at least minimize that condition.
Markus L., I don't think that is correct information. The BHW piston is 81mm STD, where the ASV is 79.5mm STD. Missing the cylinder bore to head by 1mm does not seem appropriate to me. The stock ALH head gaskets work perfectly with a +.5mm piston. Although I will admit, we alter the head gasket to improve PCP in other ways, I think getting the head gasket to match the bore closely is a very good idea.
I do not know of an aftermarket head gasket to adapt the ALH to an 81mm piston. It's unnecessary. The shape and dimensions of the ALH and the BHW cylinder head are identical. We use the BHW head gasket with BHW pistons in an ALH block.
The AHU on the other hand, we use the 2.0 gasoline head gasket, as the shape for both AHU and the gasoline engines are alike. The problem is the gasoline head gasket has only one size, so we must mill pistons and/or block to match the head gasket for proper projection.
When setting projection, It has always been my assertion that the best scenario is to create as much compression directed into the combustion chamber. Lowering compression by creating space between the piston and head is an inefficient burn. Increasing valve relief depth disturbs swirl chamber effect. It's a can of worms going there.
