guillaumeber
Hello ppl!
Long time no posts here, my mk4 has been flawless for almost a year.
Until 2 weeks ago.
I started hearing a small TOC in the driver's side front wheel while applying the brakes to a complete stop or even while slowing a little while coasting. Nothing too big but still, this was not normal. I first tought it was a LCA bushing even if they are about 1 year old and I had put the stronger audi type ones. This weekend, while applying the brakes (medium application, for a stop sign for exemple) and under certain circumstences (doesn't happen all the time), the noise came back but it's now a consecutive TOC TOC TOC TOC... while slowing; sometime I will get a last TOC when coming to a complete stop. I endured this until today when I decided to remove the wheel and check what was going on.
I found ... Nothing!
Checked the caliper fixations, sway bar bushing, link-it, shock fixations, ball joint, tie-rod, LCA bushings (both front and rear)
Did I miss something?
Happens in gear or on neutral. Didn't seem to happen on reverse but did not try a lot.
I'm just taking a guess someone already experienced something similar!
thanks a lot !
g.b.
Until 2 weeks ago.
thanks a lot !
g.b.
