UberVW_TDI
Need some Suspension Advice:
Whats your thoughts on installing a larger front sway bar (26mm H&R) on an already modified suspension?
Here is the set up I'm thinking about:
1. H&R Premium coilovers
2. H&R 24mm Rear Sway Bar (set to firm)
3. ***Would a 26mm Front Sway Bar (set to soft setting) help or hurt handling of the above set up? I'm hoping to improve laterial stiffness, and turn in response with a front sway bar. But I don't want to cause the car to understeer excessively as a front sway bar will sometimes cause on a FWD car.
I'm thinking with the firm coilovers, and stiff rear sway bar, a firmer front sway bar will match well to this set up?
I've read H&R's MKV GTI raceteam swaybar set up is 26mm front sway set to soft and a 24mm rear sway bar set to hard.
So, what are your thoughts?
