S
SkyPup
Guest
Forget the SAE stuff, just ask the dudes at Jiffy-Lube what their cheapest oil is.
<font size="2" face="Verdana, Helvetica, sans-serif">Ted, thanks, that's what I was trying to get at.Originally posted by TooSlick:
Dieseldorf,
The CI-4 rated,PAO/Ester blends would include Delvac 1, Amsoil, and Redline Oil. The VW 505/ACEA B4 rated, PAO/Ester blends would include Mobil 1, 0w-40, along with synthetic oils from Lubemoly, Motul and some of the other smaller European oil manufacturers.
<font size="2" face="Verdana, Helvetica, sans-serif">Ted, is the Euro Mobil 1 0w-40 identical to the product we can purchase in America?Originally posted by TooSlick:
The Mobil 1, 0w-40 is sold all over Europe for use in turbocharged, passenger car diesel engines. Hence it carries both the VW 505 and ACEA B3/B4 ratings.
<font size="2" face="Verdana, Helvetica, sans-serif">I currently use Delvac-1, but from reading all the above it looks like I should consider switching to either a 5W-30 (S3000) or a HD 15W-40. I can drive hard, and it is usually very hot down here. Any thoughts?The 15w-40 passed with flying colors so there was no need to test farther.. matter fact is passed all tests first and foremost so it is the perfect oil for application requiring 15w-40 oil.. the piston merits are as good as any oil tested... especially if you add in the price,, then the question is why use anything else..
well there colder climates and increaseing fuel economy..
Strictly from the standpoint of minimizing ring sticking and piston deposits and nothing else, the results of this paper would indicate that a "narrow range", PAO/Ester synthetic would work best. A narrow range synthetic would be something like a 10w-30 or 15w-40 grade. The further you deviate from this, say to a 0w-40/5w-50, the higher the level of piston deposits and/or ring sticking - all things being equal. So I think VW's recommendation to run a 5w-40 or 5w-30 synthetic oil year round makes perfect sense. VW/Audi are trying to maximize their corporate fuel efficiency numbers, hence they are recommending the thinnest oils they can get by with and still get acceptable engine life.
Ideally, VW/Audi would like to recommend 0w-30 or 0w-40 for maximum fuel efficiency, but it might result in slightly higher levels of piston deposits, so 5w-30/5w-40 is the best viscosity compromise they could come up with ....
