Mahliloltdi
I have put a few pd lift pumps in alh's with good results and couldn't help but not see if anyone ever put an inline high pressure pump with a pd motor. The stock lift pump puts out around 8psi, what if you bump that to 25+ going into the tandem pump? I figured it would be good for high HP builds where more fueling is needed.. may be wrong about that idk!.. if anyone's done it, does it run better and what kind of power difference was there. let me know what you guys think
