Old April 24th, 2018, 05:30   #1726
denismccar
Default Scan
4 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Freeze Frame:
RPM: 882 /min
Torque: 60.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00001100
Temperature: 23.4C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 882 /min
Torque: 60.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00001100
Temperature: 23.4C
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Freeze Frame:
RPM: 882 /min
Torque: 60.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00001100
Temperature: 23.4C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 882 /min
Torque: 60.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00001100
Temperature: 23.4C
Bin. Bits: 10110000
denismccar is offline   Reply With Quote
Old April 24th, 2018, 06:54   #1727
Diesel-Dan1
TDI(s): 2002 Jetta
Fuel Economy: 48
I just swapped in a good harness from my wrecked car. Still was getting MIL on cyl 2 glow plug. All plugs ohmed out within spec. Replace with Bosch plugs. Code gone. Take that for what it’s worth.
Bosch 80028/0250202022 Duraterm Glow Plug https://www.amazon.com/dp/B000CF5U76?ref=yo_pop_ma_swf
WRECKED: 2002 Jetta TDi, 5 speed, 17" wheels, rebuilt head, VNT17, PP764's and Malone Stage 4
2002.5 Jetta TDi, 5 speed swap, unlocked ECM with small tune, Studs, Stage 2 cam. Slowing working stuff over from wrecked car.
Diesel-Dan1 is offline   Reply With Quote
Old April 27th, 2018, 12:56   #1728
denismccar
Default Glow plug relay/control mechanism testing
It seems the issue is that no power is going to the glow plugs with the coolant sensor off....fuse on battery is good.... I rechecked the wiring on the new harness and it that looks good (all the cable colors match perfectly)....I checked that there is continuity from the spliced in connections to the new harness (in case new harness had a break) So, I guess the relay/control mechanism is next possible issue.... other than buying a new one, is there a way to check the current relay/control mechanism.
Old May 16th, 2018, 09:55   #1729
denismccar
Swapped out control/relay from my other tdi (same part number) and still no power to GP's. Control/relay works on other car with no codes thrown.
Old May 16th, 2018, 11:49   #1730
Vince Waldon
Vince Waldon's Avatar
Glow plug fuse on top of the battery is OK? Tested with a meter as opposed to an eyeball?!
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old May 20th, 2018, 21:15   #1731
MrAsano
Fuel Economy: 40mph
Please help me...I have the standard glow plug error with my check engine light.
Things I have done to fix the issue.
1. Change the 109 relay under the driver side steering wheel
2. Changed my glow plugs 2 times
3. Installed a new glow plug harness (2 wire)
4. Used DeoxIT on the glow plug harness
5. Checked the fuses in the fuse relay box that sits on the battery.
What else am I missing? I have a 99 TDI that was made on October 1998. It just seems like I'm chasing my tail with this.
MrAsano is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Page generated in 0.13986 seconds with 11 queries
[Output: 74.48 Kb. compressed to 64.75 Kb. by saving 9.72 Kb. (13.05%)]
