Alana
Hi, I'm new to the forum and also new to maintaining my own car and I need to know if I'm on the right track with a problem I'm having.
For the past month or so I have been having trouble starting my car (2002 Golf TDI) in the mornings. The tempuratures have been between 30 & 40F. I'm running on a 50/50 biodeisel mix.
The process would usually go as follows:
Crank - nothing
crank - nothing
crank - nothing
crank - splutter, splutter
and then it would finally start.
I would have no trouble starting the car later in the day after work.
Since this past Saturday I have been unable to start my car at all. It will crank but it won't catch and start. I'm not getting a "check engine" light or anything, the glow plug indicator is working as expected.
I thought maybe it was the EGR; that had to be cleaned a year or so ago but I think my ex optimized that with the VAG-COM tool afterwards. Also, I removed the hose from the EGR to the intercooler last night to inspect the valve. There is some residue but it is not clogged. Do you all thing there could still be obstruction in the intake manifold? Is it possible that the dealership cleaned the EGR but not the entire intake manifold?
My ex says he doubts it's water in the fuel filter because he's changed it several times and there was never any water. Nevertheless, replacing the fuel filter is on my list of things to try.
Also, I will check the anti-shudder valve when I get home. I don't think it is stuck closed because I don't remember it looking like the picture of the valve that's stuck closed. Of course, I could be wrong. I was looking around under the hood last night before I saw the thread about the anti-shudder valve so I didn't know what it was supposed to look like.
I'd like to try to get it running myself and avoid the dealership at all costs (no pun intended). So I'm planning on:
1. Checking the anti-shudder valve when I get home.
2. Changing the fuel filter....because this is easier than cleaning the intake manifold.
3. Cleaning the intake manifold after I try the other 2 things.
Oh, one other thing, it has been using about 1/4 quart of oil every 300 miles. Could this be an indicator of a CCV problem? Would cleaning the intake manifold solve this?
I apologize for the long-winded post and I would really appreciate any suggestions you may have.
Crank - nothing
crank - nothing
crank - nothing
