Recommended clutch/flywheel
louiekaps
Long Beach, Ca
2015 Golf TDI
I believe my DMF is on its way out and I am going to need to replace it soon. I am not finding many options that list they are for the 2015 tdi. I know that I cannot run a SMF, but is there a more robust DMF available for these engines? Once the emissions extension is up I do plan on tuning it so a better clutch and pressure plate would be needed.
Please share your experience with any options.
b757236
Greenville, SC
2011 JSW 2015 GSW SEL
I just did the LUK kit for my 2011 JSW TDI after 332K on the original DMF and clutch...Amazing it lasted that long. The clutch was fine but the flywheel started making a rattle at idle (springs were worn out).
I cannot tell a difference between the OEM and Luk....and the price is great. I ordered from here:
https://www.partsgeek.com/catalog/2015/volkswagen/golf_sportwagen/clutch/clutch_kit.html
adjat84th
Virginia Beach, VA
'01 Jetta TDI/'15 Golf TDI
The stock DMF was LUK in my car (good chance that's what you have as well). Went with the Sachs SRE w/DMF and organic disc. Rated for ~400ft-lbs and pedal feel and engagement to me is exactly like stock feel..quite amazing the rating with the easy pedal feel with this PP. I put in a pedal stop as well since the engagement height in the pedal travel was very high up, so now it's perfect IMO.
SBC makes a kit using the Sachs DMF as well, but I couldn't tell you how that one drives or how stiff the PP is. While nobody makes a more robust DMF, the fact that SBC also uses the Sachs version is possibly a sign to that one having better longevity?
louiekaps
Long Beach, Ca
2015 Golf TDI
adjat84th
Virginia Beach, VA
The darkside unit you linked is what I have. The DMF alone is around $400 so might be your best bet to just get the darkside kit.
louiekaps
Long Beach, Ca
2015 Golf TDI
Ive had the Sachs SRE installed for over 2 weeks now. Was able to score the Sachs DMF on Rockauto for $275. I purchased the SRE kit from the shop for $700. $650 labor for install and I am happy.
Initially I was worried with how stiff the clutch was. But after about 1000 miles it doesn't bother me and doesn't feel as insanely stiff over my other vehicles as it did at first.
gsmith41
Toronto
Mk7 Golf 6MT Highline
I just purchased the Sachs SRE kit from darkside developments and had it installed 2 weeks ago. Clutch feel is definitely improved over stock (I always thought the stock clutch pedal was way too soft). Clutch engages nicely, feels almost OEM+. Would highly recommend. For those interested, clutch kid to Toronto with shipping and duties was $1583.15 CAD. $770 for installation. I felt this was the best option compared to the Kerma DMF kit, with a south bend stage 2 daily clutch (close to $2500 CAD, plus shipping).
I have a malone stage 2 tune, after a few 6th gear pulls there is no slipping or flywheel shuddering.
tonestar
Tri-State New York
2006 Golf TDI (Canadian Import) 5 Speed, 2015 Golf TDI SE DSG, 2015 Jetta TDI SE (connectivity) DSG
How long are you guys getting out of stock clutch?
gsmith41
Toronto
I wanted to provide an update on the Darkside Developments kit (Saschs SRE with HD DMF). The clutch seems to be holding up great, but I believe the DMF has started to fail. about 30,000km since install, 99% highway mileage. Has anyone else had issues with this flywheel failing?
tonestar - I had about 90,000km on the car when I went with the Malone stage 2 tune. Within a month after the tune, the stock clutch started slipping in 5th and 6th gears under heavy throttle. I never experienced any DMF "shudder" with the stock clutch and flywheel.
adjat84th
Virginia Beach, VA
These DMFs do not like 300ft-lbs before 2200rpm, just because it's not shuddering doesn't mean the abuse isn't happening.
RIP TDI
Santa Barbara, CA
'15 GSW SE 6MT...... '01 Golf GLS 5MT.... '96 Passat Variant....
Are these basically the DMFs used with the stock Sachs clutch kit rather than an uprated version?
Midwesthick
Denver
A3, GSW, 02-Golf
Glad this thread was brought back to life. New GSW I picked up has 94k miles with a Kerma tune and I was able to get it to slip under WOT around 1800-2200rpm in 4th-6th on the stock clutch.
What’s interesting is that I can do the same thing in 1st-3rd and no issue at all. No shuddering or anything but I would like to replace the clutch so it’s just not an issue.
Bought another house this past week so I’ll get to it soon enough. Nice recommendations for replacements tho!
adjat84th
Virginia Beach, VA
Slipping clutches (and shuddering flywheels) show themselves in higher gears when the torque is requested for a longer period due to RPMs not rising as fast. Tune accordingly....
Cuzoe
Los Angeles
MK7 Golf S
I'm at just over 50k, on original clutch etc., Kerma tuned for 90% of that. I've been WOT in 6th only one time that I remember, way out in the desert trying to see how fast I could go (I called it at 110ish). So at today point I had nearly redlined 5th. Granted the car is out of wind at that speed, and 5th gets better acceleration at 90+.
Anytime I've been WOT in 5th it's after redlining 4th which always means I'm out in the desert, usually on that same long straight.
For me, the need to go WOT at 18-2200 in 5th or 6th means I need to downshift. I think that's more fun anyway. I'm not trying to test my clutch, lol.
reactor
spokane
mk7 sportwagen
I think mine is do for clutch job, tried bleeding master twice now same problem seems like clutch skips slips when taking off from first gear after driving for a while smooth when it's cold start, 129k on the clock
p.s as far as oem clutch and dmf would it be luk dmf123 and for clutch 02057 and would rear main seal be a good time to change it as a cheap insurance, thanks
whizznbyu
Waxhaw, NC
2015 Golf Sportwagen 6 speed manual. B5 died at 302k miles.
What does WOT stand for?
Google shows me world of tanks. Pfft.
RIP TDI
Santa Barbara, CA
You might consider a Sachs replacement clutch/DMF set. The Sachs TOB/slave cylinder has a better seal arrangement than the leak-prone LUK TOB and is not compatible with the LUK clutch.
gripp
Misery
13 Golf
So what if your DSG slips (mild shudder) 5-6th after Kerma DSG Tune?
They 1st said fluid issue:
So I Serviced again 2nd time in 50k) and level checked at correct temp window.
Now they say:
Our recommendation for the clutch slip is to reset the clutch pressure and synchronization points in your transmission computer
Wait what?
The funny thing is never did this prior to There tune.
Any help here would be greatly helpful.
adjat84th
Virginia Beach, VA
Shuddering and slipping are two different issues. Your 5th-6th shudder is more likely the DMF. They need to reduce fuel just a tiny bit before 2200rpm or you'll need a new DMF in short order. They know what to do in the tune.
Alternatively, downshift
adjat84th
Virginia Beach, VA
Dual Mass Flywheel
It has internal springs that allow the two masses to move independently of one another, as far as the springs will let them. When you get shudder, you're feeling the two masses bottoming out in the spring travel. Above 300ft-lbs of torque below 2200rpm or so is typically where they begin to exhibit that behavior, and it is likely to shorten their life.
gripp
Misery
13 Golf
Hmm.... well it makes sense.
Seems weird that it happened the day I uploaded DSG tune from Kerma.
adjat84th
Virginia Beach, VA
Do RPMs raise without increase in actual speed?
I didn't see you did the DSG tune and it causes the issue. I would follow their recommendation first to rule out it's actually the clutches. They're usually very solid though and should handle 400ft-lbs no trouble.
Mrrogers1
Omaha NEEEBRASKA
2011 Golf TDI 6MT, 2011 Jetta TDI DSG, 2015 Golf Sportwagen S TDI DSG
Now they say:
Wait what?
What ECM tune (tuner and stage) is it and did they realize that when they were talking to you, that you HAD THEIR DSG tune? Seems like an odd response from the tuner if they understood what was going on and that you already tuned. Maybe "reset the clutch pressure and synchronization points" means "run DSG adaptation" (which can be done in VCDS) and they weren't very clear on that? DSG adaptation is "supposed" to be done after the DSG service but in most cases, since the TCM will technically "adapt" with regular driving, I don't think it's a hard and fast rule to run the adaptation and road test procedures to complete it.
reactor
spokane
mk7 sportwagen
Thank you for sachs recommendation i will likely go with this set up, i've ordered ecs bleeder block few days ago see how much the clutch pedal feel will change before i tackle the clutch job
gripp
Misery
13 Golf
Your correct on all points. They did know it was there tunes. We've had numerous conversations regarding the issue.
Thanks for your feedback
adjat84th
Virginia Beach, VA
The SBC kit uses a Sachs DMF, so the only thing special is their clutch disc and painted pressure plate. I don't personally have experience with it, but for the price it's a bit less than desirable IMO. It also has the inferior 2-piece CSC (concentric slave cylinder) that has on o-ring along the shaft that is known to be a leak point.
The Sachs brand SRE kit with organic disc is good for 400ft-lbs of torque (more than enough headroom for the CRUA/CVCA) and pedal feel is stock like with a super smooth engagement. It also comes with the 1-piece CSC and is ~$700 cheaper than the SBC kit linked.
I personally would be very curious what the engagement feel of the SBC disc is like. I've since gone to the Sachs sintered paddle disc on my car, and it's very grabby though I can live with it. Something in between the two materials that could hold 500ft-lbs would be perfect for my setup.
Keep in mind, neither of these kits are going to cure the shudder that can be felt with a tune as the design flaw is the DMF that doesn't like >300ft-lbs before 2200rpm. Tune accordingly, and things live a lot longer ;)
