BuzzKen
Vendor , w/Business number
Basic settings 011 test, what is the mbar spread?
I will try and get that info this week.
What is it that you're looking to see....or not see?
Yes, a new PD140. That will be checked (haven't yet). But I am getting mixed results about that. I don't know, I would assume it might need an adjustment as it is not the OEM turbo...but more knowledgeable people here say it should pretty much "be spot on" as this turbo was used on a very very similar application. It has been to two very knowledgeable TDI gurus and neither one addressed that potential. But, I will see if I can get the movement checked on that rod.....see how much it takes to actuate.its not your tune. Was this a new turbo? did you check the rod adjustment? I have seen many new garret turbos set wrong from the get go.
Ok, we did a few logs and boost request follows boost produced (that is my terminology, again I am not the master at this). But the graphs plotted out on the screen very much overlay each other. Is that what you're looking to see? He said he can't find anything mechanically out of sorts. Again, this was determined by two independent TDI gurus.Basic settings 011 test, what is the mbar spread?
My low was 960 and the high went to 1080. So it's within range. I had a fault for something about the turbo boost regulator, but the freeze frame was at 0 rpm so I was like huh? Mark said he was going to update my tune to increase fuelling at low rpm to help wake the turbo up sooner and also fix my low numbers for low end torque.. I consistently hit around 297 tq without fail over 7 runs while stage 2. And with the turbo upgrade I've hit 307 once and it floated between 265-285 over 7 other runs. Same dyno too.. I even had them use their other dyno (a dynojet) and it gave the same results as the one I had always used since the beginning. My HP I'm fine with, almost 190 when at stage 2 was at like 165 or so. He said he was going to up the HP in the upper end as well. I smoke pretty good most of the time. It's not a brief puff of black like some claim. I can literally roal coal sometimes.. Sometimes it is indeed a brief one.I want to see how your vanes/boost response is. This would be good to see for the above mentioned cr stage 3 as well.
..... you went from a failing actuator symptom to a new turbo and had the same symptom but it sounds like you haven't really checked anything else - you need to verify that the new turbo actuator is set right - they just slap those things on at the factory and don't care how they're set. Secondly, as far as I can tell you haven't verified that your vacuum pump even works. You also need to verify your N75 works. There are so many possible problems that you're ignoring. Also sounds like you haven't verified your entire vacuum system is free of leaks. All of these things will cause this problem. You also must acknowledge that a larger turbo will take more time to spool - especially compared to a BRM turbo which is absolutely tiny.
Inspect the Turbo inlet pipe for cracks and inspect the turbine for damage and feel that it spins freely. I'm not sure what year it started, but on a CR TDI, a cracked inlet pipe will allow air in post-maf and if the MAF isn't reading air passing, the car responds as if air is not available, makes the car a complete dog.Exhaust leak? I don't think so....no odor (as I did when my EGR cooler failed...kind a liked it though) and no sounds of exhaust leak. Really it runs and idles fine.....unless you want some power out of it. Before the issue it was a freakin rocket with JUST the Stg2 Malone. It then developed this issue and no matter what was thrown at it or WHO looked at it.....it's the same lazy *****!
I don't think you would hear anything, it would be an air vacuumAAR, thanks....mine is a BRM with a new PD140. I will check the inlet. But again, I don't hear anything weird....would I?
Is your lift pump working?
