DJGonzo
Well I got the ECU in and it won't start. I have a few codes. Maybe someone can help?
I am missing some wires regarding pedal sensor and MAF but I want to see if I can at least get it to start. I don't know if I fried this ECU on the bench a while back by plugging in the wrong plug
I was able to read out the ECU with my flashing tool at least though
Pics:
Thanks guys
Code:
Saturday,07,January,2012,16:38:09:46862
VCDS Version: Release 11.0.0
Address 01: Engine Labels: 038-906-012-AGR.lbl
Control Module Part Number: 038 906 012 BD
Component and/or Version: 1,9l R4 EDC G100AG 2507
Software Coding: 00001
Work Shop Code: WSC 06103
Fault Codes have been Erased
6 Faults Found
4 - Glow Plug/Heater (Q6) Circuit: Malfunction
P0380 - 35-10 - - - Intermittent
5 - Needle Lift Sensor (G80): Open or Short to Plus
P1247 - 35-00 - -
2 - Modulating Piston Movement Sensor (G149): Electrical Malfunction
P1354 - 35-00 - -
7 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 35-00 - -
0 - Quantity Adjuster (N146): Upper Limit Reached
P1562 - 35-00 - -
1 - Quantity Adjuster (N146): Lower Limit Reached
P1563 - 35-00 - -
Pics:
Thanks guys
