I replaced injectors a couple weeks ago, no problems and no leaks when I leak checked everything.
today, i found this.....
https://youtu.be/Mrh6LUdMRpc
The fuel lines are dry, and the top of the pump seems dry. I can't tell where this is coming from.
Is this a location that the seals can be redone on the car? or should I start planning to pull the pump
