joep1234
- Joined
- Jan 2, 2014
- Location
- NC
- TDI
- former '04 Beetle TDI, now 2x '15 Audi Q5 TDI's, 2007 Dodge Ram 4x4 6.7
Had the bearing roar and a sloppy outer right cv joint on my Beetle. Followed Scurvy's write up but had some troubles. The wheel bearing had been replaced before and it was all bound up. Took the knuckle off easier than trying to remove the bearing out in the car (tried 1 1/2 hrs). Removed the axle nut and axle, scribed the ball joint, removed the bolt that held the strut and spread the mount and removed the strut, removed the tie rod (trick-remove the nut and hit the side of the knuckle at the tie rod mount. It fell out on the second hit, instead of hitting the bottom threaded area). Did all of this with a impact wrench in less than 10 minutes. Took the knuckle to the bench with a couple wood blocks, socket that matched the hub diameter and a 5# sledge. 5 hits later it was apart. Used the Harbor Freight bearing removal tool that Scurvy mentioned and was able to remove the bearing with it after removing the c clip. Had the bearing out with the tool but there was some damage from previous replacement. Cleaned it up, warmed the steering knuckle with a torch and took the bearing out of the freezer that had been in there for 2 hours. Taped in to start and used the HF tool to seat it quickly. Took a right angle grinder to cut off the bearing race and clean up previous damage and used the HF tool to install the hub. 30 minutes later it was back together and going for a test drive. I could do it again in 1 1/2hours or less. Need to get it aligned sometime this week if it will stop raining. Thx Scurvy for your write up. It gave me the confidence to do it myself and save some money.
