tbailey4
- Joined
- Nov 24, 2005
- Location
- Livonia, Suburb of Detroit
- TDI
- 2006 Jetta, 6spd conversion. 2001 Jetta, Alh, wife's car.
I know this has been discussed many times and i gained valuable info from the previous readings. I found good info and I was entertained by people trying to fix the leak by wiping sealer along the seam. Thanks to all that input on the subject.
My 97 Passat has developed a leak at the top cover of the injector pump. I have ordered the repair kit from bosch and found a socket to get the tamper proof bolt out. I cleaned the area very well to see exactly were the fuel was coming from. After thourgh cleaning I removed the top cover to find the o-ring that is probably the culprit.
My question is, can I also remove the injection quality section easily to replace the o-ring at that point. Or, are there a bunch of little pieces that are going to fall out of place? I see no leak at the base of the IQ block, but I read that leaks have occured here in the past.
I understand that removing the electrical block will require that it be carefully marked in place and that Vag-Com is required to set the IQ. i have access to Vag-com and a person who knows how to use it. I am just not sure what happens when you remove the IQ section. thanks for all and any input. Tim
