aslspiderman
Before I get to my rabbit hole, here's my situation:
I have a 98 Jetta, purchased in 2012 from a forum member. Current setup is:
Sprint nozzles--I assume that means 520 sprints
K03/04 turbo
Tune of unknown origin.
The above upgrades were done previous to me purchasing the car. Through my research on this site and talking to Rich at fix-um-house who did the work, I don't know who did the actual tune. It may be Alligator or Rocketchip??? I do know the tuner went through a few iterations to get it the way the OP wanted it.
Whatever the origin, it's a fun little car. It's pretty quick and pulls hard all the way to redline. It still gets low 50's on long drives. Bottom line--I like it the way it is.
Every two years since 2015 I've struggled to get it to pass smog because of egr readiness issues. Matt, my favorite guru and I think the tune is the culprit.
Here's the Rabbit hole--I will be getting a new tune. I'll be going with Malone. Initially I was thinking stage 3, but discussing my situation with Owain at Malone, he says that my current nozzles are a choke point for the potential of the turbo. Here are his words:
"These nozzles max out around 130hp, the turbo is capable of flowing more but you're limited by fueling"
he suggested DLC1019 and a stage 4 tune if I wanted to max out the turbo.
I'd like to go with just the stage 3 for minimal cost, but stage 4 and bigger nozzles sounds more fun
I'd like some feedback on the stage 3 tune with my current setup. Anyone out there have a similar setup? How do you like it?
Is there anyone out there with a stage 4, DLC1019 and a k03/04? How do you like it?
Mike
K03/04 turbo
Mike
