altabound67
03 Jetta, new to me, the clip holding the line into the slave was missing. Put in clip and it leaked. Replaced O-Ring and there is still leak. Do not believe the leak is between the slave and the fitting (ie,O-ring). Suspect it is between the fitting and the tube. The fitting will turn on the tubing. Is this as it should be? If so, what is the seal between the tubing and fitting. If I have to change the hose how in heck do you get at the other end? What is the magic? What are the chances of sealing between the fitting and the tube?
