Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Passat TDI Picture Gallery
Passat TDI Picture Gallery Do you have a Passat TDI? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old July 20th, 2017, 07:28   #121
PlaneCrazy
TDI(s): Gone...
My son's is just shy of 300k km now. Hasn't sold it, he finds it handy for running errands for larger items for the bike shop he co-owns. He will not do the timing belt, will get rid of it when that needs to happen (about 2 more years of driving). By then I plan to sell him my Mk VII Golf and get another Golf, this time a wagon. So far it's holding together well mechanically; original transmission, never had a fluid change (when VW said lifetime fluid, I took them seriously), original cam, balance shaft drive replaced with geared unit back at 181k km.
Mike
Hers: '17 Golf TSI Sportwagen 5-MT
His: '18 Sportwagen 6-MT 4MOTION
'16 Marinoni Genius/Campy Record, '94 Marinoni Special/Campy Record
PlaneCrazy is offline   Reply With Quote
Old July 20th, 2017, 07:40   #122
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Just turned 400k km. Original Cam, no BSM or automatic trans to worry about any longer either.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old July 20th, 2017, 07:46   #123
PlaneCrazy
TDI(s): Gone...
The one thing that's really killing my son's is corrosion. The 12-year warranty is now over since last October, and there are LARGEW rust holes in the left rear door. But VW didn't want to touch it with a 10-ft pole as it was the result of a poor collision repair. Can't blame them, they did change the two front doors, two front fenders, trunk deck (twice), right rear door (in part), and repaired the left rear quarter panel, over the years.
Mike
Old July 20th, 2017, 10:16   #124
Windex
Windex's Avatar
See if you can find a door in the local wrecking yard - my local yard has a good selection of B5.5s in most colours...
Old July 30th, 2017, 12:07   #125
Tom_B
We're at 211k miles, original cam, geared BSM at 90k and TC replaced at 145k. Don't want to jinx it but still running strong, drives and rides great.
14 Touareg TDI; 14 A6 TDI
No longer in the driveway: 03 NB TDI, 04 Jetta GL TDI, 05 Passat GLS TDI, 09 Touareg Lux TDI
Tom_B is offline   Reply With Quote
Old July 30th, 2017, 12:44   #126
PlaneCrazy
TDI(s): Gone...
Moot point now. It finally died on my son, in New Brunswick, in the middle of nowhere. CEL, and won't shift. No doubt the torque converter blew. If he can't get it fixed at a reasonable cost, the car will be junked in New Brunswick.
I'm not confident it will be worth the cost to fix it, so I suspect it has driven its last miles (223 km) on a flatbed from wherever he was to Fredericton. The second, and probably last time it will be towed (previous time was when the steering rack seals failed, about 7 years ago).
Final tally will likely be 297,700 km. It's been a good car, some weak points (especially the CV joints, the balance shaft chain and the transmission/TC), but solid.
Mike
Old March 25th, 2018, 12:58   #127
leon10tagg
leon10tagg's Avatar
Up to 167k miles or 267k kms.
01 Golf Tdi, FMIC, CR1756 turbo, PD intake, Newman cam, EGR delete, BV, modified intake, 80mm MAF, turbo back 2.5" Milltek, 11mm IP, R520s, 3bar MAP, TD tuning box, PD130 O/C,Spax adj's, Eibach A/R bars, powerflex bushings, 312mm discs, top and bottom strut braces
05 & 04 Passat AWX, 98 Impreza turbo, 97 A4 1.8T sport
http://forums.tdiclub.com/showthread.php?t=298788
leon10tagg is offline   Reply With Quote
Old March 26th, 2018, 14:51   #128
otty
otty's Avatar
Just hit 215,000km though the engine isn't original to the car and I have my doubts in general as to whether or not the odometer has been rolled back...
Malone tuned stage 1 and loving it!
otty is offline   Reply With Quote
Old May 4th, 2018, 10:09   #129
Tom in PT
Fuel Economy: 41 mpg in '05 ; up to 57 in '13
73,350 miles.
Tom in PT is offline   Reply With Quote
Old May 4th, 2018, 10:42   #130
Windex
Windex's Avatar
Now at 450k km
Old May 21st, 2018, 07:49   #131
James & Son
TDI(s): 2006 Jetta
Now at 450k km
At that mileage whats going through your mind as to "when" and "what"?
James & Son is offline   Reply With Quote
Old June 5th, 2018, 08:31   #132
JonnyObnoxious
JonnyObnoxious's Avatar
TDI(s): 05 VW Passat
245,000 miles.
Just getting serious. Planning on a 5sp manual swap, RR suspension, and a bunch of custom body and interior work.
Step 1: buy a VAG-COM
JonnyObnoxious is offline   Reply With Quote
Page generated in 0.15910 seconds with 10 queries
[Output: 106.43 Kb. compressed to 89.15 Kb. by saving 17.28 Kb. (16.24%)]
