Old April 9th, 2019, 20:32   #31
turbobrick240
turbobrick240's Avatar
That's a rough situation. I doubt you'll be able to get any compensation from the mechanic, even if he was at fault. It's just not something that can easily be proven. I'd just say no thanks to his replacement car offer, and never use his services again.
Old April 9th, 2019, 22:22   #32
bizzle
bizzle's Avatar
Yep, and even if you could "prove" it and "win" the case, unfortunately you're still a ways off from collecting.
bizzle is offline   Reply With Quote
Old April 14th, 2019, 12:49   #33
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
It doesn't really matter what happened: the car threw a rod while in your mechanic's care and while they were test driving it after a repair. We could speculate on why that happened but regardless I would say they owe you an engine.
So if a car is in a mechanics care and something happens they are automatically responsible?
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old April 14th, 2019, 12:59   #34
Probably not. And I'll acknowledge there's a lot about this situation we don't know, so perhaps they aren't responsible. But to me it looks like something happened that they're not sharing that caused the damage. That's a pretty dramatic failure to just spontaneously happen. Not common, either.
2002 Jetta wagon, 407K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 14K. Principal, http://www.idparts.com
Old April 15th, 2019, 08:03   #35
Matt-98AHU
Matt-98AHU's Avatar
Fuel Economy: Depends on which TDI :)
Originally Posted by melbatst View Post
Quantum,
I'm about 3 hours away (central coast) but can get to Portland - would be thankful for any involvement. Mad at myself for getting into this position.
I've got family that way... Waldport and Newport-ish.
Maybe we should link up sometime. Could give you a hand with the car whenever I'm in the area visiting.
Though at this rate I may not be up until sometime near 4th of July.
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old April 15th, 2019, 23:35   #36
Ol'Rattler
Ol'Rattler's Avatar
From what I read, it sounded like the mechanic was fumbling around trying to open the hood while the engine was running away. If that is the case, he should have tried to stop the runaway immediately before doing anything else.
With a runaway, redline doesn't mean anything because the engine is consuming oil that is not metered by the fuel system so the engine will usually reach the highest RPM that it is capable of and then quite often hydrolock if you don't get it shut down immediately. Like in a few seconds after the runaway starts.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old April 16th, 2019, 15:28   #37
MarsBar
Fuel Economy: B4V - 37 combined; ALH - 53 best highway so far
Does the statement "with the mileage the car had on it that catastrophic failure wasn't a surprise" bother anyone else? Sounding like some tap dancing. Awaiting further details on the situation.
MarsBar is offline   Reply With Quote
Old April 17th, 2019, 03:48   #38
bizzle
bizzle's Avatar
It doesn't bother me in the sense that it's a typical response from a typical non-TDI specialist/owner, reflecting a typical perspective regarding mileage on vehicles.
That's generally what will fall out of people's mouths when they see our odometers--even mechanics. I don't think it's being used as some sort of tap-dancing so much as reflecting his worldview in regards to older/high-mileage vehicles and his responsibility when something that seems unrelated to the repair he did breaks.
We already figured this guy shouldn't have been working on the TDI so there isn't much to say about that part of the problem at this point.
Old April 19th, 2019, 18:08   #39
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Has everyone in this conversation who keeps pointing at the injection pump work, taken into account that as the runaway happened, if the ip was the cause simply shutting off the key would have turned the engine off?
This seems like its a turbo failure, feeding the engine on engine oil. Someone needs to check the turbo and intercooler for oil.
Old April 23rd, 2019, 07:30   #40
MarsBar
Shutting the key off won't stop a runaway, hence the term. Also won't usually result in a rod being thrown clear through the block. Engine will still be toast, though.
Any updates on a post-mortem of the engine?
Old June 14th, 2019, 13:33   #41
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Sometimes it will if the ASV valve works and isn't carboned up real bad.
I'm interested as well.
Old June 14th, 2019, 16:15   #42
Typrus
If you have a functional ASV it will shut it down with key-off.
His phrasing, as you put it, strikes me as deceptive.
It would sure be nice to get hands on it and do a quality failure analysis...
My gut says this is his responsibility- he played with the fuel pump then the engine failed. Injection pump repairs should not be conducted by those unwilling to pay close attention to detail.
As a mechanic, I'm sorry that some people in my profession are worthy of the general distrust our vocation brings...
Have you made any headway with this?
1996 VW Passat TDI Sedan 5mt-- Sold @ 300k+
2002 Jetta Sedan GLS/TDI 5mt -- 112k+
Typrus is offline   Reply With Quote
Old June 15th, 2019, 07:38   #43
JB05
Fuel Economy: 43/41/40
OP, any updates?
JB05 is online now   Reply With Quote
Old January 17th, 2020, 06:03   #44
ninedee_golf_tdi
Originally Posted by JB05 View Post
OP, any updates?
Last Activity: 05-03-19 04:12 PM
ninedee_golf_tdi is offline   Reply With Quote
What if.. the "repair" is a new engine? patbob Dieselgate - VW Group Emission Scandal 7 August 16th, 2016 23:08
Upper Intake "charged" hose blew tdisquared VW MKIV-A4 TDIs (VE and PD) 6 May 15th, 2012 20:26
2005.5 engine "hesitation" while driving? Guttboy VW MKV-A5 Golf/Jettas 13 July 10th, 2011 08:03
2006 TDI Blew UP! Part 2 "The Nightmare Begins" skiges TDI 101 9 June 20th, 2010 21:05
"Mileage" vs. "MPG" vs. "Mile range" vs. "Miles per tank" boyelectric TDI Fuel Economy 33 August 19th, 2002 06:06
Page generated in 0.16133 seconds with 11 queries
[Output: 125.66 Kb. compressed to 105.55 Kb. by saving 20.11 Kb. (16.00%)]
