Old October 14th, 2010, 14:12   #1
Guttboy
Guttboy's Avatar
Fuel Economy: Seeing AVG at 48.4 (mix hwy/cty)
Default 2005.5 engine "hesitation" while driving?
Hi Everyone, It is good to be back here in the forums!
Here is the issue I currently have on my 2005.5 Jetta TDI: When driving in all conditions and I have the cruise control on it seems as though the engine "hesitates" or "burps" when driving along. It feels like an immediate loss of power for half a second and then is fine. I also noticed this when driving without the cruise control on and it is the exact same feeling. This has been going on for about 3 months now.
The other issue that I am noticing is that the car seems to "vibrate" or "pulse" when stopped at a light. It is a very very slight vibration throughout the car when sitting at a stop light. It does not occur all of the time but has been going on for about a month now.
Thanks again for the assistance....it is much appreciated!
PS...I have tried several different fuel stations for diesel and does not appear to be fuel related as far as I can tell. The "hiccup" is as if power was taken away from the engine for a fraction of a second. This is a manual transmission as well.
Mike....
2005.5 MkV Jetta TDI, Platinum Gray/Gray Leather, Package 2, Manual Trans, OEM Fog Light Mod from EMT, Remote windows with OEM Key FOB
800 Mile Club...IT CAN BE DONE
Guttboy is offline   Reply With Quote
Old October 14th, 2010, 18:09   #2
MyAvocation
MyAvocation's Avatar
Not sure about the hesitation issue, so I'll refrain from guessing.
Regarding the vibration/shaking at a stop light: How many miles? Is your DMF original?
A worn DMF will shake the vehicle after disengaging clutch or neutral on a DSG, which is most noticable after vehicle stops moving.
MyAvocation is offline   Reply With Quote
Old October 14th, 2010, 21:10   #3
benpfree
benpfree's Avatar
TDI(s): 2005.5 jetta
I have the same issue with my 2005.5 jetta. I started this thread recently:
http://forums.tdiclub.com/showthread.php?t=296449
I haven't been able to find anything conclusive yet. I'm going to have my car looked at given the few suggestions I've had on the forum so far. I will post results when/if I have any.
2005.5 Jetta TDI sedan, black on black, all stock except RC1+
benpfree is offline   Reply With Quote
Old October 14th, 2010, 21:15   #4
Henrick
Sometimes I have this issue too but mine isn't with DMF but SMF. So I decided this must be probably fueling dependant...
Henrick is offline   Reply With Quote
Old October 15th, 2010, 08:33   #5
Guttboy
Guttboy's Avatar
Thanks Folks! Appreciate the response. MYAV, I have the original DMF....the car has 78K miles on it. Benpfree and Henrick I am going to check out the thread Benpfree put up and see if that gets me closer to a solution. A more accurate description of the "hiccup" it feels as if the car comes out of gear or if it was a bad shift on an automatic car if that makes sense. Thanks!
Mike....
Old October 15th, 2010, 12:01   #6
Jnitrofish
Jnitrofish's Avatar
Fuel Economy: Bad on short trips, good on long trips.
And my car does that little intermittent vibration at idle at stoplights (link in my sig). If its not the DMF (since its intermittent and also on cars with SMF's, thats more likely), it seems that it may be the fluid dampened motor/tranny mounts showing their age, as theinternot fixed his vibe by replacing his that leaked.
[ 2005.5 :: 06/05 Jetta 5m Franko6 BEW Cam/Malone Tuned - Equipped for towing (Bosal/Airlift/Tekonsha) || 2005.5 :: 05/05 Jetta 5m Tuned (Wife's Car) || 2006 :: 02/06 Jetta DSG Malone Tuned (Dad's Car) ]
[ 4 TDI tally: 4 cam jobs, 5 timing belts, 4 alternator pulleys, 2 DMF, 1 G60/VR6, 1 Jetta ] [ Explained engine vibration
Jnitrofish is offline   Reply With Quote
Old October 15th, 2010, 12:06   #7
flyvsdrive
I was having this identical problem on my 2005.5 Jetta 5 spd. It began around 130,000 miles on the odometer. While cruising at a steady speed, the car would lose power for about 1 or 2 seconds then regain power. It would not kick the cruise offline. A few months later at 134,000 miles, while climbing hills on cruise at a steady speed (typically around 60 - 65 mph), the car would lose power and the cruise would go offline. The car would remain at low power with no cruise available until I restarted then everything was back to normal. Finally at 135,000 miles an early morning start was accompanied by the tell-tale "lupping" sound with metallic ticking sounds above 2000 RPM. It's as if a switch had been flipped overnight. It turned out the cam was the cause for the sounds.
New cam is in but I'm still having some low boost problems. After looking around, I've determined that the turbo's vane actuator has failed -- it doesn't hold vacuum pressure. So, that could have been a cause for the drops in power. Check your actuator and see if it will hold vacuum pressure and if the actuator rod will extend when vacuum is applied. Should be fully extended at 20" vacuum.
flyvsdrive is offline   Reply With Quote
Old October 15th, 2010, 23:24   #8
MyAvocation
Now that you've mentioned turbo actuator, regarding hesitation, I remember reading a thread on it. I believe either MOGolf or DieselDorf posting steps to isolate this, so do a search.
Old October 20th, 2010, 10:03   #9
Guttboy
Guttboy's Avatar
I will check on the turbo actuator. Just completed a 1200 mile trip up to Denver to see Nickelback in concert (great show btw) and the car did great but a SLEW of issues are coming up with regards to it. I TOTALLY forgot that I have an extended warranty through Warranty Direct that takes me to 100K and 7 years. So I am well within that. Literally within the past 3 months several issues have arisen. The driver door will not lock all the time with the key FOB now. It takes a twist of the key in the lock to secure the car. It think it is time to exercise the warranty now! Flyvsdrive....I have no metalic sounds at all. Simply the hesitation that may indeed be the turbo actuator....I will look on the thread about hesitation and take a peek! Thanks folks will report back with my findings!
Mike....
Old October 20th, 2010, 17:28   #10
Windjammer
TDI(s): MK4 & Mk5
How many miles on the fuel filter? If it's more than about 15,000 I'd change it.
00 Jetta TDI GLS Auto Black w/Beige leather, Phatbox
06 Jetta TDI Shadow Blue w/Beige Pkg 2 DSG W/NAV & Phatbox
06 Jetta TDI Blue Graphite w/Grey Pkg 2 DSG W/NAV & Ipod dock
06 Jetta TDI White w/Beige Pkg 2 DSG
06 Jetta TDI Black w/Beige Pkg 0 5MT
Windjammer is offline   Reply With Quote
Old October 20th, 2010, 19:15   #11
hevster1
TDI(s): 98 NB
Fuel Economy: 40-42
Do not overlook the pump in tank. I had 2 BEW's do this so far and both ended up needing a pump.
NJ's best shop performing Quality Repairs on TDI's, Toyota, Lexus, Scion and other European and Asian cars as well as Motorcycles & ATV's. Written warranty, reasonable prices. ASE L-1 & A-9 Master re-certified. NEW LOCATION: Montague NJ. Hunter Wheel Alignment. Snap-on Tire Service.I don't need to have specials, my prices are better already!
www.mmautocycle.com
hevster1 is offline   Reply With Quote
Old November 3rd, 2010, 10:39   #12
dae06
dae06's Avatar
I would wager a bet that this is a frayed wire in your drivers side door harness. This happened to me along with the fuel door not opening, windows and interior lights working intermittently for me. I tore it apart and spliced the ground wire and all is fine (for now).
I too have experienced the engine hiccup. I'll be interested to see what the culprit is.
2005.5 Jetta 1.9 TDI, Manual Transmission.
220,000 miles as of 03/12/2019; New Cam and TB as of 12/1/2014, New EGR valve and EGR cooler as of 3/29/2016.
dae06 is offline   Reply With Quote
Old July 9th, 2011, 17:12   #13
lil' Smoker
Any resolution to this issue yet? I'm working on this problem as well with my '06 jetta. After an extensive chat with my VW dealer's service manager, I removed the valve cover and took a look at the cam. My cam is galled very bad on 3 or 4 of the lobes and the followers are not in good shape either... So back to the conversation with the service manager at the dealer, he has had numerous complaints of this and it has been the same thing over and over for the most part. He took a guess of what the problem is and explained what to look for under the valve cover. Might be something you could check out too if the problem is still present. took me about 45 min start to finish to find my issue.
lil' Smoker is offline   Reply With Quote
Old July 10th, 2011, 08:03   #14
MkVer
Fuel Economy: Low/Mid 40's @ 7000ft MSL
The idle shudder is pretty common. There are quite a few threads on the issue. Some chip tunes address/solve the issue. Otherwise you'll need to to get VagCom and possibly get under the hood*, thats if you want to "fix" it.
* http://forums.tdiclub.com/showthread...ght=rough+idle
2005.5 Jetta. BRM. Panzer plate, Frostheater, Upsolute chip tune, Mufflerectomy, Colt II Cam, Lower Grille Block.
MkVer is offline   Reply With Quote
Page generated in 0.14238 seconds with 10 queries
[Output: 118.85 Kb. compressed to 98.69 Kb. by saving 20.16 Kb. (16.96%)]
