Mike_04GolfTDI
- Joined
- Nov 19, 2003
- Location
- Richmond, BC, Canada
- TDI
- Mine: 2019 Golf R DSG, Wife's: 2015 Golf Comfortline TDI
For those who haven't seen my recent threads on the aftermath of a timing belt failure, I put a new timing belt kit, and a new head on my engine.
The exhaust valves had hit the pistons when the belt failed, but the intake valves did not leave a mark at all.
Well, I took my new head off again today, and now there are signs that the intake valves have been hitting! I'm not sure how this is possible. The timing belt was installed correctly, with the proper lock tools. Torsion value was adjusted with VCDS to achieve 0.0 degrees. (It was a valid reading, because I was finely adjusting it between -1.0 and 1.0, so it's not way off and reading 0).
The head gasket is a 3 hole gasket, because that's what the car came with from the factory. I measured piston protrusion and that was all normal. In fact, based on my readings I theoretically could have used the thinner two hole gasket.
So I'm not sure why the intake valves were lightly hitting the pistons, but they were.
My theory is that maybe the piston wrist pin bushings were very slightly damaged during the previous timing belt failure, and so the pistons are exceeding their normal travel and are slapping the valves. I'm really not sure what else it could be, unless the cam is not made right or something! Examining the pistons and trying to find unwanted movement at the wrist pin doesn't reveal much. If that's the problem, it's very difficult to tell.
Well, I have used pistons in excellent condition ready to go in, but I'm kind of taking a step back to figure out why the valves might have been hitting. I'm not sure what else I can do, other than time the cam properly, and install the proper head gasket based on the piston protrusions.
The connecting rod bearings and the journals on the crank look perfect, so I don't think connecting rod bearings could have anything to do with this.
If things get too stupid I'll be looking for a 2015 Golf TDI...
