ALH Mass Airflow Connector
TDI Jim
Gaithersburg, Maryland
1996 Passat, 1996 Passat Variant (RIP), 2002 Jetta Wagon, 1995 Passat Variant TDI conversion brought back from the dead, 1997 Passat Variant project, and returned 2014 Passat
I noticed when changing my mass air flow sensor there are 5 prongs on the sensor and only 5 female connectors in the plug. Is this correct or is my plug missing the 5th connector? Thanks for your help everyone!
Sent from my SM-N910V using Tapatalk
TDI Jim
Yes.
terminal chart:
Thanks Windex. I got a repair plug and wires from ID parts, so will start working on it.
Just took the back off the cinnector and only see red, green, black and yellow (with black stripe) wires in the wiring harness, so may have to visit a junkyard, unless there are any other suggestions?
TDI Jim
My bad, there are only 4 connectors, so plug is correct as is, got it now, thanks Windex!
