Redman84
Wednesday night near the end of a 3 hour drive the instrument lights went haywire flashing on and off and the radio turned off. It cleared in less than a minute or so leaving my airbag light on. Yesterday was fine but today while driving a short distance the radio turned off and the ABS and ESP lights came on. VCDS had a lot to say. See the log below. I'm certainly not trying to be lazy here but am posting it up in case anyone recognizes an obvious pattern. In the mean time I plan to check and clean the grounds, fuses, etc and do lots of online searching. The radio code is normal as I need to replace the antenna base.
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 GN
Component: 1,9l R4 EDC G000SG 4308
Coding: 00002
Shop #: WSC 01266
VCID: 629EA385DD51B447073-4B1E
WVWSP61J43W584256 VWZ7Z0C7460537
1 Fault Found:
17911 - Load Signal from Alternator Term. DF
P1503 - 35-00 - Implausible Signal
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
Shop #: WSC 01266 785 00200
VCID: 343215DD32256AF7A5F-5184
3 Faults Found:
00495 - ESP-Sensor Unit (G419); Supply Voltage
012 - Electrical Fault in Circuit - Intermittent
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Part No: 1C0 909 605 F
Component: 03 AIRBAG VW61 0202 0003
Coding: 12339
Shop #: WSC 01266
VCID: 2708F291F6F3116F10D-513C
2 Faults Found:
00532 - Supply Voltage B+
06-10 - Signal too High - Intermittent
07-10 - Signal too Low - Intermittent
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 01266
VCID: 2F381AB1DE03492FD8D-5184
2 Faults Found:
00926 - Terminal 30
07-00 - Signal too Low
00926 - Terminal 30
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 L
Component: KOMBI+WEGFAHRSP VDO V11
Coding: 07232
Shop #: WSC 16262
VCID: 313C1CC9C8375FDFCE9-513C
No fault code found.
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 01266
VCID: 70BAD9CD03BD16D7817-513C
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8A Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 01266
VCID: 372822D1265381EF80D-4B1E
Subsystem 1 - Part No: 1C1959801A
Component: 8A Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C1959802A
Component: 8A Tõrsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811A
Component: 8A Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
Component: 8A Tõrsteuer.HR KLO 0009
6 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
52-10 - Supply Voltage Too High - Intermittent
53-10 - Supply Voltage Too Low - Intermittent
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 E
Component: Radio NP2 0008
Coding: 04031
Shop #: WSC 01266
VCID: 221EE3859DD1F447473-513C
2 Faults Found:
00856 - Radio Antenna
36-00 - Open Circuit
End----------(Elapsed Time: 05:10, VBatt start/end: 12.7V/12.5V)-----------
Coding: 00002
Shop #: WSC 01266
1 Fault Found:
Coding: 0019458
3 Faults Found:
Coding: 12339
Shop #: WSC 01266
2 Faults Found:
Coding: 00118
Shop #: WSC 01266
2 Faults Found:
00926 - Terminal 30
00926 - Terminal 30
Coding: 07232
Shop #: WSC 16262
Coding: 00006
Shop #: WSC 01266
Coding: 00258
Shop #: WSC 01266
6 Faults Found:
Coding: 04031
Shop #: WSC 01266
2 Faults Found:
