Jakub
I've looked thru all the posts on p0101 code. I checked the cam and and lobes and found a little wear on a few lobes. It's visible but you can't feel the wear when running your fingers across
My issue is black smoke and when I accelerate under Load and car boosts it's starts jerking really really bad. As the turbo boosts it's as if the car stops it and power loss.
As I said I have p0101 code. I unplugged the MAF sensor and the car runs without jerking.
Should I assume I should get a new MAF?
