Could be the dreaded crank pulley bolt coming loose.
If and when you start it, take a reading of the injection timing with VCDS.
If it is OK (midway or to the top of the green line on the graph) AND the camshaft is in time it will probably be something else. But, If the injection timing and the camshaft are retarded relative to the crank then that pulley bolt needs to be checked to see if it worked itself loose and is causing the crank pulley to bounce back and forth. That in turn will chew not only the pulley but the end of the crankshaft.
It should take an enormous amount of torque to loosen that bolt.
If it does not feel loose with a 24" breaker bar on it, it is most likely OK and you have other things to look at.
If you want to see if it is getting fuel, pull the glow plugs and crank it. You should see a mist of fuel coming out of the glow plug holes for evidence.
