Old September 11th, 2014, 08:10   #1
ikezilla
Default Fan Control Module location in 09'?
Before I go tearing into the car, can anyone tell me where I will find the module to check it out and possibly replace it?
ikezilla is offline   Reply With Quote
Old September 11th, 2014, 08:24   #2
FowVay
FowVay's Avatar
It's mounted on the big fan motor itself.
FowVay is offline   Reply With Quote
Old September 11th, 2014, 08:37   #3
Chad@EuroTec
The module is not replaceable separately from the fan. No way to test either, except using VCDS. You can check the small fan by disconnecting and applying 12v/ground directly to the terminals.
Chad@EuroTec is offline   Reply With Quote
Old September 11th, 2014, 09:21   #4
tdiatlast
HVAC fan or coolant fan? I'm confused...
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2014 Cadillac ELR, purchased 3/18
tdiatlast is offline   Reply With Quote
Old September 11th, 2014, 10:04   #5
ikezilla
is it not one control unit that effects both fans? After some research a little while back, and one code that had been thrown, I ordered the FCM because it was cheap and I hoped it might do the trick. There were no noticeable issues other than the fan code (not sure what it was exactly). Now, the AC stopped working, and I want to replace this part before I do anything else.
Old September 11th, 2014, 10:26   #6
ikezilla
and if my AC isn't working, will that effect the radiator temps for a 2 hour drive I have to make before I can get to it all?
Old September 11th, 2014, 10:27   #7
Ol'Rattler
Ol'Rattler's Avatar
Apparently. He wasn't talking about the fans, he was talking about the controller that controls both which is integral to the larger fan.
Digitally controlled stuff on these cars works differently then the old analog controlled components the older cars have.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old September 11th, 2014, 10:39   #8
Ol'Rattler
Ol'Rattler's Avatar
If the fans are not working correctly, as long as you don't get stuck in stop and go traffic, engine cooling should be OK. At 25+ MPH, the fans don't even come on for engine cooling. Just be prepared to pull over and shut the engine off if you are moving at a snails pace for very long.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old September 17th, 2014, 12:38   #9
jmontal03
TDI(s): 2009 TDI JSW
my 09 only seems to have one functional fan-small passenger side fan. I've read and perf. a test- ign. on A.C. on engine not running no fans. start engine small fan runs after a short delay big fan nothing. Does that prove the large fan dead?
jmontal03 is offline   Reply With Quote
Old September 17th, 2014, 13:09   #10
BITRBO
TDI(s): '09 JSW DSG
^IDK, but I wish I could at least get the small one to run on my car... Neither of them work when connected to the car, but work just fine when connected to a separate 12v D.C. supply.
And as far as the OP's concerns about overheating... I've been driving my JSW for almost 2 weeks now w/o working rad fans, through stop & go traffic, in this ball-soup called south Florida, and the temp gauge has never even flinched past 190* Unless you're going through the mountains or towing something substantial, you should be just fine at normal highway speeds.
Mods: 2Micron Pure Flow / Contain Flow kit
BITRBO is offline   Reply With Quote
Old June 21st, 2015, 08:33   #11
jwp175
jwp175's Avatar
Question
Bump on this older thread ....
I am having similar issues with my 2010 Jetta TDI. I removed the fan assembly and tested the fans by directly hooking 12volts, and NOTHING.
I Replaced the entire fan assembly with a new one that DID work when attaching 12v directly. However, that did not resolve the Fan 1 control module short to ground code. And my ac compressor still will not engage. Now, I am throwing a diesel filter code. The codes just keep mounting.
I thought the fan control module was a separate unit under the battery tray, or is that just on the mk4's and older?
Any help would be appreciated ...
Jwp
__________________________________________________ _____
2002 Jetta TDI ... Reflex Silver ... 199k and back on the road for almost 2 years, after 4 months up on blocks under repair ... mine
2010 Jetta TDI ... traded in the '98 Porcelain Blue with 258k ... her's
jwp175 is offline   Reply With Quote
Engine Control Module Location egh2001 TDI 101 2 April 7th, 2014 09:25
02 jetta fan control module location and installation showman89_08 TDI 101 3 October 2nd, 2009 08:51
Comfort Control Module Location andste TDI 101 1 July 25th, 2009 12:51
no a/c fan/ fan control module saabguru VW MKIII-A3/B4 TDIs 33 July 23rd, 2006 19:51
96 Passat (location of AC fuses, fan control module) TDIPA28235Pilot VW MKIII-A3/B4 TDIs 5 June 17th, 2006 14:09
Page generated in 0.16215 seconds with 11 queries
[Output: 102.72 Kb. compressed to 86.98 Kb. by saving 15.74 Kb. (15.32%)]
