Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Other VW Group TD(I)s
Other VW Group TD(I)s To keep with the theme of VW Diesels, this message area is for discussion of other VW Group Diesels. Yes, TD's are also welcome.
Old February 14th, 2012, 22:23   #1
markomarko34
Default help please coding door control module?
I'm coding something wrong and now the rear electric windows not working anymore.may be anybody help with information.
Chassis Type: 3C0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 76 7D
VIN: WVWZZZ3CZ7P040452 Mileage: 139760km/86842miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Not registered 0011
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 997 020 T HW: 03G 906 018 CE
Component: R4 2.0l PPD1.5 G 5159
Revision: --H25--- Serial number: VWZCZ000000000
Coding: 0000038
Shop #: WSC 85642 123 999999
VCID: 397D29D709C9
No fault code found.
Readiness: N/A
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 050 D HW: 02E 927 770 AE
Component: GSG DSG 070 1404
Revision: 04507000 Serial number: 00000607181430
Coding: 0000020
Shop #: WSC 00028 028 00001
VCID: 1321BB7F4BE5
Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0940027572
Coding: 0013605
VCID: 326F1EFBD4BF
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 67D9BFAF2FFD
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000004250791
Coding: E100860F1004100207010107F101FF03A1196F4E320000
VCID: 306B14F3DAB3
Part No: 3C1 955 419
Component: Wischer VW461 001 0101
Coding: 00046997
Shop #: WSC 85642
Part No: 1K0 955 559 AE
Component: RLS 250706 014 1201
Coding: 00733221
Shop #: WSC 85642
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 03 AIRBAG VW8 030 2522
Revision: 10030000 Serial number: 003B1PDTPD7+
Coding: 0012339
VCID: 306B14F3DAB3
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00007000 Serial number: 3C5953507P
Coding: 0001111
VCID: 2E570A8BC087
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 HW: 3C0 920 871
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 85642 123 45725
VCID: E1CD21B741D9
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C0670601BF
Coding: 3FFD1C04C21002
VCID: 214DE1B78159
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 397D29D709C9
Part No: 3C0 905 861 F
Component: ELV 026 0380
3C0905861F ELV 026 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1123
Revision: 11006001 Serial number: 00000046268805
Coding: 0000183
VCID: 3C7330C306FB
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.136 H07 1806
VCID: 346318E32EAB
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: A_ KSG PQ46 ELV 042 0472
Coding: 18910A0001865E7F3F02151520084F2A007840
VCID: 397D29D709C9
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1123
Revision: 11006001 Serial number: 00000060868804
Coding: 0000182
VCID: 3D753DC71DE1
Address 53: Parking Brake Labels: 3C0-907-801-53.lbl
Part No SW: 3C0 907 801 G HW: 3C0 907 801 G
Component: EPB VD8HC005 013 0005
Revision: 013
Coding: 0000012
Shop #: WSC 07988 995 94353
VCID: 2647F2ABE877
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 R
Component: Radio GR0 019 0023
Revision: 0001905S Serial number: VWZ2Z2F1882278
Coding: 0010002
VCID: 356525E725D1
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1113
Revision: 11005001 Serial number: 00000000460761
Coding: 0000144
VCID: 3D753DC71DE1
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1113
Revision: 11005001 Serial number: 00000000467012
Coding: 0000144
VCID: 3E773ACB10E7
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
Component: Parkhilfe 8-Kan 004 0011
Revision: 00004000 Serial number: 82930619810042
Coding: 0001014
VCID: 285BFC93E263
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D550D87CD81
2 Faults Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation
End ---------------------------------------------------------------------
markomarko34 is offline   Reply With Quote
Old March 11th, 2012, 08:38   #2
MakDad
TDI(s): 2012 Jetta.
let me know if you figure it out. got the same problem it seems...
MakDad is offline   Reply With Quote
No signal/com from either rear door control Module (J388) Sootman VW MKV-A5 Golf/Jettas 14 December 3rd, 2017 03:34
No signal/com from either rear door control module (J388) Sootman OBD Scanners 4 January 28th, 2010 05:07
Left Rear Door Control Module mjhandy Ontario 4 July 14th, 2009 19:01
Door Control Module & Sound Cover blustik TDI 101 0 February 27th, 2008 14:46
URGENT Need help with door control module -=PYRO=- TDI 101 1 March 4th, 2006 09:24
Page generated in 0.14736 seconds with 11 queries
[Output: 60.86 Kb. compressed to 56.77 Kb. by saving 4.08 Kb. (6.71%)]
