Old December 1st, 2010, 12:04   #1
Robertson
Default 01044 : control module incorrectly coded - 09-00 - adaptation limit surpassed
Closed
Robertson is offline   Reply With Quote
Old December 1st, 2010, 12:36   #2
Santos_V
Ross-Tech AssociateVendor
Santos_V's Avatar
Please post a complete autoscan. We need to see all the information from the ECU and the Instrument cluster.
Santos@Ross-Tech.com
Santos_V is offline   Reply With Quote
Old December 1st, 2010, 13:37   #3
Robertson
Closed
Old December 1st, 2010, 19:54   #4
vwemporium
Why don't you e-mail Ross-Tech directly and they'll probably take a "crack" at helping you
Best,
Jack
vwemporium is offline   Reply With Quote
Old December 1st, 2010, 20:44   #5
Sebastian
Agreed, the alternative would be that you simply update to the latest version of VCDS-Lite as we do believe that there is something "wrong" with the version you are using at the moment.
http://www.ross-tech.com/vcds-lite/download/index.html
Sebastian
Sebastian is offline   Reply With Quote
Old December 2nd, 2010, 04:29   #6
Robertson
Closed
Old December 2nd, 2010, 15:10   #7
Robertson
Oh well, guess i hit a brick wall. Cheers
Old December 2nd, 2010, 16:53   #8
m1ketdi
TDI(s): Leon BKD
Fuel Economy: 50+mpg
Hey, I think I know how to solve this for you. Login to engine, go to adaption and read block 00. Then click save. Then exit it all and rescan for fault codes. Should be gone after that,
m1ketdi is offline   Reply With Quote
Old December 3rd, 2010, 03:40   #9
Robertson
Closed
Old December 3rd, 2010, 09:12   #10
Sebastian
Contact us directly please.
Sebastian
Old December 3rd, 2010, 09:39   #11
Robertson
Closed
Page generated in 0.16541 seconds with 10 queries
[Output: 92.91 Kb. compressed to 76.84 Kb. by saving 16.07 Kb. (17.29%)]
