Old April 28th, 2006, 10:12   #1
Bugzilla
Default '06 Jetta VAG Codes (VAG-COM Newbie)
Is there a specific TDI reference for the newer models? Or will much of the older information still work?
I am about to plunk down the $$$ for a VAG-COM (don't tell the wife).
I have a 2002 NB and now the 2006 Jetta. Both are TDI. NB is a 5 speed, and the Jetta is the DSG.
Sorry if this has been asked a thousand times. I did do a half hearted search, but didn't have much luck.
Bugzilla is offline   Reply With Quote
Old April 28th, 2006, 10:38   #2
wolfsburg_de
Ross-Tech AssociateVendor
Fuel Economy: 33.5 mpg, mostly city
Thumbs up
These should get you started. For the Jetta:
http://www.ross-tech.com/vag-com/cars/Golf5.html
And for the NB:
http://www.ross-tech.com/vag-com/cars/vwmkIV.html
Also, for the NB, check out this page:
http://www.ross-tech.com/vag-com/cars/tdi.html
Keep in mind that since your '06 Jetta uses CAN-Bus diagnostics, you will need a HEX-COM+CAN or HEX-USB+CAN (they are backwards compatible with the older vehicles like your NB as well).
support@ross-tech.com
wolfsburg_de is offline   Reply With Quote
Old April 28th, 2006, 11:46   #3
Bugzilla
Yeah I had sort of figured that out from what I had read, but it is good to have in black and white. I was curious about backward compatiblity though. That is good news.
And thanks for the links, I will put them to good use!
Old May 2nd, 2006, 20:33   #4
flipside
flipside's Avatar
TDI(s): 06 Jetta
Newbie here as well and looking at the vag-com, I just bought 06 Jetta TDI with DSG. My brother in law has the o5 passat TDI, will the mentioned interfaces work on the passat as well.
flipside is offline   Reply With Quote
Old May 3rd, 2006, 05:41   #5
Sebastian
The HEX+CAN series is fully backwards compatible, so yes it will work on the new Jetta and the "old" Passat.
Sebastian
Sebastian is offline   Reply With Quote
Old May 3rd, 2006, 22:30   #6
penclnck
I'll chime in with my usual "get the USB cable" since many new laptops don't have serial ports anymore. There is no real differance in using the USB vs COM cables... just how they plug up to a computer.
So for the post above me... HEX-USB+CAN will do the 2005.5 and newer car as well as the old cars back to 1994 (and beyond).
Sebastian... gonna be in stinkin' Jersey for Waterfest again? Rumor has it there will be some good looking girls there this year.
Pencilneck blah blah blah
penclnck is offline   Reply With Quote
Old May 4th, 2006, 02:11   #7
Sebastian
The plan is to be there, yes.
You mean like that?!
Sebastian
Old May 4th, 2006, 08:33   #8
TwinDiesel
*pant pant pant*
His - '06 Jetta TDI, black, Pkg 1, 5MT, 17" Visions, OEM spoiler
Hers - '06 Jetta TDI, spice red, Pkg 1, DSG
Soot happens
TwinDiesel is offline   Reply With Quote
Page generated in 0.13701 seconds with 10 queries
[Output: 80.88 Kb. compressed to 68.92 Kb. by saving 11.96 Kb. (14.79%)]
