Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old July 4th, 2018, 10:28   #1
ctennyson
TDI(s): 2010 Jetta
Default My 2012 Touareg
Hello Guys,
My 2012 Tourareg TDI has sprung an oil leak form the turbo. I hear this is a major operation to repair and requires the engine to be pulled ?
Can anyone confirm is this is the case and recommend a mechanic in Oakville\Burlington to repair ?
Colin
ctennyson is offline   Reply With Quote
Old July 4th, 2018, 14:35   #2
Uberhare
Uberhare's Avatar
Fuel Economy: Depends on what I'm towing!
Turbo is leaking (i.e. ingesting oil) or feed line (external leak)?
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old July 4th, 2018, 19:09   #3
ctennyson
TDI(s): 2010 Jetta
Believe it or not, both....
Turbo is ingesting oil and the feed line is leaking also, mechanic is telling me he has to pull the engine to repair.
Old July 10th, 2018, 19:18   #4
proto
TDI(s): 2003 Golf
I'll go with not
proto is offline   Reply With Quote
Old July 10th, 2018, 19:21   #5
proto
TDI(s): 2003 Golf
Maybe get a second opinion from someone reputable before proceeding.
Old July 11th, 2018, 05:20   #6
ctennyson
TDI(s): 2010 Jetta
I would love to have a reputable mechanic in Oakville.
Old July 11th, 2018, 18:29   #7
proto
TDI(s): 2003 Golf
If the external leak can be fixed without pulling the engine, you should probably start there and then monitor the oil level closely to see if it's still dropping. Did your mechanic say how they determined that the turbo was leaking internally? If the turbo is failing then you need to address that before it grenades, but if that's the case then you should have been told that there was excessive oil in your intake, excessive shaft play in the turbo, or something along those lines. The problem is that many 'mechanics' pretend they know what they are doing when they are guessing, and unless you are confident that this person knows what they are talking about then I'd be hesitant to have the engine pulled. You could try messaging BuzzKen on this forum, his shop is in Markham but it'd be worth the drive to know for sure. Lots of people recommend Precision Tuning in Concord as well.
Old July 12th, 2018, 06:10   #8
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Perjad at precision is good people. Knows his stuff.
To my knowledge, the only way to address the turbos on the TREG is to pull the engine.
Yuck.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old July 12th, 2018, 08:13   #9
oilhammer's Avatar
Fuel Economy: fantastic
The labor to R&R the turbo on a 2012 T'reg CATA 3.0L TDI V6 engine is 3.4hr and you most certainly do NOT have to drop the engine.
For comparison, the labor time for a turbo on a 2012 Jetta sedan CJAA engine is a whopping 9 hr.
www.cardocautomotive.com
Old July 13th, 2018, 05:35   #10
ctennyson
TDI(s): 2010 Jetta
Appreciate the responses. I will contact Buzzken.
Colin
Old July 14th, 2018, 08:50   #11
HPsenicka
I would add Total Mechanical Services just outside Orangeville as another highly recommended VW/Audi specialist.
HPsenicka is offline   Reply With Quote
Old Yesterday, 20:30   #12
Savageman69
Savageman69's Avatar
yah the turbo is on top and pretty easy to access...and pretty much all oil cooled turbos with ingest some oil and have some in the intercooler pipes....hopefully you find someone who knows what they are talking about
2012 Highline Touareg v6 TDI - 8spd - Silver - Weathertechs - Buzzken Downpipe/Dpf/Scr Pipes - Hybrid 2260 - 4 Bar Map - JR Auto Performance/Buzzken Stage 3 Tune - 31 BFG k02s - Cayenne Trans Coding - Gutted/Painted Muffler - Full Led Swap
Savageman69 is offline   Reply With Quote
2012 Touareg TDi ctennyson Ontario 2 April 16th, 2018 08:07
My 2012 TDI Touareg Savageman69 Other TDI/Diesel Picture Gallery 57 March 18th, 2018 14:54
Touareg 2012 Tdi ctennyson Ontario 18 February 15th, 2017 06:07
2010 vs 2012 Touareg silverfstop VW Touareg TDIs 12 February 26th, 2015 14:30
2012 touareg help!! nelsonfarms TDI 101 5 December 9th, 2012 04:20
Page generated in 0.12782 seconds with 12 queries
[Output: 103.92 Kb. compressed to 86.98 Kb. by saving 16.95 Kb. (16.31%)]
