Old July 12th, 2018, 12:02   #16
AndyBees
AndyBees's Avatar
If you are using an adapter, there may not be a need for bell housing clearance using an upgrade such as that might fit a TDI Car. I really have no clue. But, any upgrade using the diesel bell housing will require minor grinding at two or three areas to provide clearance for either the G60 style SMF or the DMF. The DMF requires a midge more grinding for clearance. I've noticed that my DMF has been ever so slightly rubbing in just those areas I ground down. (tranny is out for maintenance at the moment)
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
AndyBees is offline   Reply With Quote
Old July 12th, 2018, 13:35   #17
jimbote
jimbote's Avatar
so you're obviously NOT using a luk 17-050 ... my advice: try it you'll like it
jimbote is offline   Reply With Quote
Old July 12th, 2018, 15:42   #18
casey823
Fuel Economy: 45 mpg with auto jetta, 50+ with the golf
Thanks for the input, I am running an adapter so it should be good. Sorry to the OP if I hijacked your thread!
casey823 is offline   Reply With Quote
Battery Issue- Vanagon ALH conversion Rebubula TDI Conversions 3 March 28th, 2018 20:17
Vanagon ALH tdi conversion Rebubula TDI Conversions 2 June 14th, 2017 14:00
Temperature Gauge - VW Vanagon TDI 1.9L ALH swap Rebubula TDI Conversions 3 May 24th, 2017 09:02
1991 GTI ALH conversion (for sale) couttsdesign TDI Conversions 2 September 29th, 2013 07:31
Rebuilt ABD Vanagon Transmission for TDI conversion dieseltdi Private TDI Items for Sale/Wanted 1 February 29th, 2008 20:47
Page generated in 0.11160 seconds with 12 queries
[Output: 60.67 Kb. compressed to 54.81 Kb. by saving 5.86 Kb. (9.66%)]
