Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old July 3rd, 2018, 22:02   #1
NewJettaOwner
TDI(s): 2006 Jetta
Default fob part number doesn't match model year
Hi, I just bought a 2006 Jetta but it came with only one working key & fob. The dealer ordered a second key for me, but instead of being like a valet key it's actually the key half only of a fob set. I'd like to buy a 2nd fob to attach to the key portion, but here's the problem....the current working fob is part number
HLO 1J0 959 753 DC which apparently is only compatible with 2001-2005 Jettas. I ordered the exact part number from ebay but couldn't get it to program regardless of the different ways I tried (including the simplistic instructions in my manual.) That escapade already cost me shipping and restocking fees, so do I take another chance and order a fob that IS supposedly compatible with a 2006 Jetta but DOESN'T match the current fob part number that I own? And if I do and the new fob successfully programs, will that "deprogram" my current fob because they aren't identical? Or is it most likely that at some point the current fob case broke and someone put the insides into the older (and cheaper) case version?
Thanks for your thoughts!
NewJettaOwner is offline   Reply With Quote
Old July 11th, 2018, 16:21   #2
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
You are correct that the DC part number is incorrect for your vehicle. That is only for MkIV vehicles as you mentioned.
However, there are two different part numbers for the MkV.
1K0-959-753-P-9B9 and 1K0-959-753-H-9B9. They are not interchangeable. If you would like, PM me your VIN and I can find the correct part number for your car.
Fixmy59bug is offline   Reply With Quote
Amount in offer letter doesn't match buyback calculation CHawk Dieselgate - VW Group Emission Scandal 35 February 20th, 2017 17:44
Buyback offer doesn't match agreement sbh1973 Dieselgate - VW Group Emission Scandal 13 December 17th, 2016 19:33
Fuel mileage doesn't match scan gauge Robo48 VW MKIV-A4 TDIs (VE and PD) 14 April 10th, 2012 16:54
Cylinder head gasket doesn't match kpiazzisi TDI 101 25 September 30th, 2011 23:41
Alarm doesn't work so key fob doesn't either sackman VW MKIV-A4 TDIs (VE and PD) 4 November 22nd, 2010 19:01
Page generated in 0.13389 seconds with 12 queries
[Output: 53.62 Kb. compressed to 49.57 Kb. by saving 4.04 Kb. (7.54%)]
